Can I scratchbuild this in 1/20 scale?
    March 2005
Posted by philo426 on Tuesday, June 11, 2019 1:59 PM
Since I built my Eindekker I have a hankerning for a big Gotha.I have plenty of sheet styrene ,just have to determine the dimensions.Should be a challenge!
    March 2005
GAF
    June 2012
Posted by GAF on Tuesday, June 11, 2019 2:43 PM
I say Go For It!  A friend of mine used to build WW1 aircraft for wargame use.  He built some beautiful scratch-built models (at a much smaller scale).  I do want to ask why 1/20th scale?
Gary
    March 2005
Posted by philo426 on Tuesday, June 11, 2019 2:52 PM
Because that is the scale of my scratch built Eindekker.
    March 2005
Posted by philo426 on Tuesday, June 11, 2019 2:55 PM
    March 2005
Posted by philo426 on Tuesday, June 11, 2019 3:05 PM
Although the Gotha will be mostly plastic ,here is the Eindekker in the construction phase.
    March 2005
    March 2005
Posted by philo426 on Wednesday, June 12, 2019 3:17 PM
46 inch wingspan 24 inch length
    September 2012
Posted by GMorrison on Wednesday, June 12, 2019 4:49 PM
I was just now doing the math. Yep, almost four feet (1.18 meters). Sure you can build it. My own challenge with larger scale models is that the engines turn into time consuming projects, but hey it's cool.
Gary, decimal scales are really easy to work with when scratchbuilding, in particular if the subject was metric to begin with or old drawings are dimensioned that way. By WW1 Germany had made the metric system compulsory.
The Gotha 5 had a wingspan of 23.70 meters. Divide by ten; 2.37 meters. Divide by two; 1.185 meters or 118.5 cm. Easy to do in your head.
Nice project, Philo! I want to see working bomb drops!
    March 2005
Posted by philo426 on Wednesday, June 12, 2019 5:04 PM
Might put slot car can motors in the engine blocks just for fun!
    September 2012
Posted by GMorrison on Wednesday, June 12, 2019 5:08 PM
Yes!
    May 2011
Posted by Real G on Wednesday, June 12, 2019 5:51 PM
Are you planning on using dope to paint your Gotha?  I tried it on a wood framed WW I aircraft hangar and it tightened up nicely!  It also gave the tissue paper a smooth finished texture.  For that kind of size, RC airplane construction makes sense.  So yeah, why not do it?  Like the fictional band from the movie "This Is Spinal Tap", your model scale does not stop at 10.  It goes to 11.
“Ya ya ya, unicorn papoi!”
    March 2005
Posted by philo426 on Wednesday, June 12, 2019 6:14 PM
Well I am making the wings out of  3 or 4 ply laminated plastic sanding to profile and adding styrene strips to the wing surface.I plan on using  a trick I learned about 40 years ago to use hex grid paper and carbon  paper to do the cammo.then use a fine brush to fill in the hexes over the base purple color.
    March 2005
Posted by philo426 on Wednesday, June 12, 2019 9:00 PM
Ok drew a template for the Starboard wing.
    March 2005
    June 2019
Posted by danham on Thursday, June 13, 2019 7:54 AM
Hi there. Am I right, you decided to build your own project (model)? It is so hard to prepare and to plan everything. My respect Yes
    March 2005
Posted by philo426 on Thursday, June 13, 2019 10:56 AM
Yep should be a challenge!
    March 2005
Posted by philo426 on Tuesday, June 18, 2019 9:34 AM
Getting the wing together.
    March 2005
    June 2014
Posted by Tanker - Builder on Tuesday, June 18, 2019 10:32 AM
Philo;
 I want to say sir; I am glad to see you have adopted a child's assembly toy for braces and clamp surfaces. Being a TEX-LUG ( Texas LEGO user Group member) I use the Bricks a lot :
    I also use COBI,BRIK-TEK and MegaBlocks as well as LEGO .Brand here is a moot point , usefulness is the key.
    March 2005
Posted by philo426 on Tuesday, June 18, 2019 10:42 AM
Yes I decided to cut slots in the bricks to hold the wing formers,seems to work well!
    March 2005
Posted by philo426 on Tuesday, June 18, 2019 10:45 AM
    March 2005
Posted by philo426 on Tuesday, June 18, 2019 10:46 AM
I have a lot of Lego s for sure!
    March 2005
Posted by philo426 on Wednesday, June 19, 2019 3:11 PM
I decided to use 7/32 brass tubing as the leading edge of  the wing.
    March 2005
Posted by philo426 on Wednesday, June 19, 2019 3:13 PM
    March 2005
Posted by philo426 on Thursday, June 20, 2019 1:33 PM
Had to carve the wing end out of red oak.Had to lace the lower wing to the brass tube with a .10 guitar string.I will conceal it as work progresses.
    March 2005
