Degrease in a bath of lacquer thinner, then avoid touching the parts with your pizza-stained fingers. Handle the fret by the frame.
An overnight soak in a mild acid such as household vinegar will slightly etch the metal surface. Rinse and allow to air dry (rubbing with a towel may bend fine detail shapes).
