Building Clear Models with Regular Polystyrene Glue ( Tamiya )
    June 2014
Posted by Tanker - Builder on Saturday, August 24, 2019 3:46 PM
Okay now.
       This is for everyone who has done it. Wants to do it and Doesn't like to do it! What about clear models do you find scary? Is it the idea that the glue you use will fog the clear? Well, that's why I don't use Super Glue anywhere near clear parts.
      Believe it or not. I have had phenominal luck with Tamiya glue in the Green label Bottle. I have found though that it has to be an unused bottle or one dedicated to clear parts only! I found if you use your regular bottle you will get some discolored crazing near the edge of the parts.
    The fact is if the glue is contaminated in any way, this will happen. Mainly if you use it on other colors of plastic this happens. How? well, every time you touch that beautiful little pointed brush to join two pieces of plastic , it picks up just a micron or two of the colored plastic you're gluing. Eventually the glue gets contaminated by the different colors of plastic and other stuff like sanding dust you didn't see. Once in a while, look in the bottom of the bottle and you will see what I mean.
     You can filter this out and do so with a plain old coffee filter and a clean and dry old bottle and brush.The brush will have to be cleaned too, remember. Okay, we got around the glue. Now how do you do it? Never put glue on in the middle of a piece. Always find a corner and let capillary action work for you.
      Never ever squeeze the piece beyond what it takes to hold it together firmly and gently. Now remember, Do NOT! if you paint detail inside,Do NOT , let the paint get anywhere where the glue has to go! What will happen, is the glue will begin to lift the paint and it will result in a stain inside your clear part!
     If you want to detail something, Say a frame or inner structure, then Make sure the join area is near the edge of the part, Not in the center! Otherwise you will have two ghostly lines on either side of your added part. If you need more info on using regular Tamiya glue on Clear, Message me . Tanker - Builder
    September 2012
Posted by GMorrison on Saturday, August 24, 2019 5:19 PM
But, how do you avoid getting gluey fingerprints all over it. I always do.
    June 2014
Posted by Tanker - Builder on Sunday, August 25, 2019 7:15 AM
Well " G " Whiz:
   You do not touch the wet seam or the brush with yer fingers. I forgot to mention too, that you don't want to use tape anywhere near a glue surface or seam. Capillary action will do this. It will run along the seam into and around the tape. It will eat through the tape ( if you use Scotch Magic Mending tape as I do ) and it will make a trip around the tape ends as far as it can go. Can you say Tape Mark?
 Now that said, " G " keep yer fingers out of the glue. Wear gloves ( Surgical ) Okay?
