You moved too fast. Building a kit - putting the parts together is the quick bit, but you still need to let everything cure.
always let primer and paints cure and dry for a minimum of 8 hours. Overnight or 24 hours is better.
Never use Tamiya clear coats over Vallejo. For some reason they just don't like each other. Vallejo clear gloss is just as good as is AK's gauzy coat which is crystal clear, designed for their Xtreme Metal range but works fine on other brands.
Always wise to have plastic dessert spoons to hand where you can slap paint on and protective clear coats to see how they react to each other. It is a learning process.
the lesson from this is just SLOW DOWN. This hobby is not a rush production line thing, it is a hobby which you learn new techniques, refine existing ones and produce the best you can.
take a look at my most recent builds on the aircraft forum, the Nick Ki-45, Shinden and HK's latest 1/32 Lancaster. That took 3 Months!
For my latest bench adventure, look in the armour section for Amusing Hobbies latest and first full interior kit, the Ferdinand and Strabokran 16t.
So, don't try and do everything at once. With paint, just give everything overnight or 24 hours.
