Glueing painted parts together
    November 2019
Posted by RobertCosta on Monday, November 11, 2019 11:47 AM
How do you glue painted parts together?
    March 2007
Posted by armornut on Monday, November 11, 2019 2:31 PM
   Hello, it isn't recommended. Plastic cement " welds" the parts together, paint creates a barrier between the parts preventing the glue from performing.
   It is best to glue parts before painting or clean the mating surface of paint.
     I have had luck with CA (super glue) it works on a different principle than cement, NOT RECOMMENDED for clear parts. Hope this helps.
we're modelers it's what we do
Posted by Tojo72 on Monday, November 11, 2019 2:46 PM
The liquid cements like Tamiya Extra Thin melt everything including paint,so I will apply it sparingly to a painted joint and it works fine,never had a problem,never had a mess that a little touch up couldnt fix.
Posted by Don Stauffer on Tuesday, November 12, 2019 9:54 AM
I always clean at least some of the paint away from joints.  If the join area is small I scrap the paint away.  For that, I keep an X-acto handle with a used blade in it.  When I replace the blade on my primary knife, I then transfer that blade to my scraping brush.
For joints that have more surface area I take a shortcut and just dimple through the paint in a few spots with a drill in my pinvise.
