starwarsdude
Thanks, I tried with a sanding stick but couldn't make meaningful contact. So I ordered some 800 grit sandpaper that I can cut up. Is 800 a good grit for airbrushed acrylic paint on a plastic model?
It's not really. It could be ok for a flat finish if you use light pressure and don't dig in. Look into investing in a set of Micro Mesh sanding pads. They'll last you a while, and they do a better job.
https://www.amazon.com/M-jump-Touch-Sanding-Polishing-Grits
We all started modeling thinking that paint would work to some degree to smooth over or hide blemishes. No longer true.
Today's paints, applied with an airbrush, can be very thin coats. If anything, a good thin coat of paint will make flaws more apparent. I've learned to think of my paint finish quality as a result of working at a fine finish from the inside out, not the other way around.
