Tamiya Acrylic Paint Not Water Based?
    October 2019
Posted by starwarsdude on Tuesday, March 24, 2020 12:18 AM
I just got some Tamiya XF18 Medium Blue paint and it has warnings about isopropanol and glycol. I thought acrylic paints were water based. Is this stuff more toxic than Vallejo Model Air?
Thanks!
Tags: tamiya
    August 2005
Posted by Phil_H on Tuesday, March 24, 2020 1:13 AM
starwarsdude
"Acrylic" does not simply mean water based. The term acrylic refers to the film-forming component of the paint, it doesn't refer to the reducing agent used. There are alcohol based acrylics, such as Tamiya and GSI Creos Aqueous Hobby Color, lacquer based acrylics (GSI Creos Mr Color) and acrylics based on other chemicals, like the Vallejo paints.
If the film-forming component is composed of acrylic resins, that is the determinant that makes it an acrylic paint. You may sometimes see people say that Tamiya isn't a true acrylic because it's not water based. This is not true, because, as mentioned above, the type of reducing agent used is irrelevant.
I'm not sure about the current formulation, but the original early-80's formulation of Tamiya paint contained about 25% water.
Posted by Tojo72 on Tuesday, March 24, 2020 5:13 AM
Yes you are correct,not water based.
    April 2004
Posted by Jon_a_its on Tuesday, March 24, 2020 5:34 AM
For best results Use X20a Tamiya acrylic thinners, or Mr Color Levelling Thinner, or IPA. Brobably in that order. You can use water to thin, but this is less than optimal. Always mix paint & thinner outside the cup, tattooists ink pots, old 35mm film containers, communion thimbles, etc. in case it goes all... rubbery (Vallejo & any IPA based thinner is a no-no!)
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    July 2018
Posted by Tickmagnet on Tuesday, March 24, 2020 6:12 AM
I've had the best result using Tamiya X20A thinner. Some folks use Tamiya lacquer thinner with the acrylic paint but I have not tried that.
    August 2005
Posted by Phil_H on Tuesday, March 24, 2020 6:39 AM
Tickmagnet
If you use Tamiya lacquer thinner (or the aforementioned Mr Color thinner/levelling thinner) you can thin the paint far further than conventional wisdom dictates. 80% or more thinner is no problem. It'll still stick without beading/running. It's great for tinting/fading/shading effects.
I've also found that with gloss paints, the lacquer thinner seems to give a better gloss than X-20A or any of the alcohol alternatives.
As always, practice on a paint mule before doing it on a live build.
    August 2005
Posted by EdGrune on Tuesday, March 24, 2020 6:50 AM
Remembering my organic chemistry labs we were taught to discern organic components using their smell (thanks Dr Wilson).  To my nose, the alcohol component in Tamiya's thinner smelled remarkably similar to Expo Dry Erase board cleaner.   I procured a pump bottle of the stuff from the office supply cabinet and tested my hypothesis.   Worked like a champ.  When your hobby shop is closed or too far a drive - check out the local Staples office supply store.
As always, test a new material/process before committing to your current masterpiece
    July 2004
Posted by stikpusher on Tuesday, March 24, 2020 9:35 AM
EdGrune
Excellent tip! My Tamiya thinner is running low, the closest hobby stores are a bit longer of a drive now, and good luck finding any sort of alcohol on store shelves these days.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2012
Posted by GMorrison on Tuesday, March 24, 2020 9:52 AM
stikpusher
EdGrune
    October 2019
Posted by starwarsdude on Wednesday, March 25, 2020 12:27 AM
Very impressive and generous info!!! Thanks! Big Smile
    September 2018
Posted by Papa Bear on Wednesday, March 25, 2020 8:35 AM
Wow, can we make a nice 15 year old scotch out of Tamiya thinner...?
I love Mr. Roberts - I think I'll have time to watch that later!
Best regards,
    July 2004
Posted by stikpusher on Wednesday, March 25, 2020 10:00 AM
GMorrison
stikpusher
EdGrune
Now that sort of alcohol, I’m already stocked up with... Wink
       - Plankton
LSM
    July 2004
Posted by stikpusher on Friday, April 17, 2020 7:57 PM
Bump
       - Plankton
LSM
    January 2014
Posted by Silver on Sunday, April 26, 2020 10:27 AM
Just "google "it.That's what most people get their information at."google" makes an expert out of people.Tamiya paints work well with Tamiya thinner And so on.
