Does anyone have a scan of the instructions for this kit they could send me. Its the newer DDay Invasion rebox. Thanks in advance!
I have this kit in one of my storage bins buried in the closet, though it was the original numbered release. Directions should be the same though. If you can hold out until the weekend I should be able to get it dug out. Though if anyone else has it handy go for it!
Robert
"I can't get ahead no matter how hard I try, I'm gettin' really good at barely gettin' by"
You may be able to blow these photos up big enough to use them.
http://amphibiouswarfare.blogspot.com/2012/08/whats-in-box-lcvp-lindberg-132.html
I found some links to images of these online, biut they all go "404".
Try this:
https://www.google.com/search?q=lindberg+lcvp+instructions&sxsrf=ALeKk00WUoXGdIwNDSRih3dP9XJ07ufn2g:1589905550585&source=lnms&tbm=isch&sa=X&ved=2ahUKEwiNmMbcq8DpAhUTr54KHSVlAMQQ_AUoAnoECAsQBA&biw=1600&bih=762#imgrc=ChJHGoeIMtv5WM
There are some decent build write ups.
Carve off cast on ropes and replace.
Carve off round bolt heads and replace with hex stock.
Replace the .50s.
Retire rangers and find a better set.
