Model Master Acryl paints peeling off
    June 2020
Posted by JimLo on Monday, June 8, 2020 12:11 AM
Three of my new bottles of MM Acryl paint I airbrushed ( thinned with Model Master Acryl thinner) peeled off when I used Tamiya masking tape on it a week to two weeks after it's been dried. What am I doing wrong ? I washed the plastic but did not prime. I don't prime for my Tamiya paints and never have issues. Do Model Master Acryl paints require priming to adhere ? My Vallejo paints peel too but from just regular handling but I think that's from not fully being able to mix those paints in their dropper bottles. Any ideas why I'm having bad luck with my MM Acryl paints and Vallejo paints airbrushed with no primer ? I use their same branded thinners too. Thanks.
    February 2004
Posted by dhenning on Monday, June 8, 2020 6:16 PM
I always prime with acrylics.  Normally use the Model Master Acrylic primer but have also used the Tamiya grey and white spray can primers.  Acrylics seemed to be more sensative to me.
  Look online for fingernail polish mixer or tatoo ink mixer.  Small battery powered mixed with plastic tips that you can link together to mix the Vallejo paints.  Just use a pair of pliers to pull the top off and mix away-but keep the mixer ends submerged or you can create a mess with spinninp paint droplets!
    September 2012
Posted by GMorrison on Monday, June 8, 2020 6:35 PM
I agree with the above. Acrylics on plastic are touchy.
Lately I've been using the Badger Stynylrez primer and I really like it. Long term results TBD.
Bill
    June 2020
Posted by JimLo on Monday, June 8, 2020 6:39 PM
Thanks.
I guess I've been spoiled or lucky with Tamiya Acrylics. I've never had to prime for Tamiya paints on any of my model surfaces.  Thanks again.
    June 2020
Posted by JimLo on Monday, June 8, 2020 6:48 PM
Also I'm conducting an experiment with Vallejo Model Color, Model Master Acryl and Tamiya Acrylic paints primer and not primed on plastic. I'll let it dry for a week and will do a Tamiya masking tape test on them. I'll let you know the results.
    April 2020
Posted by Eaglecash867 on Monday, June 8, 2020 6:57 PM
When you do your testing, just make sure to rip the tape off quickly.  If it can handle a test like that without peeling, then you've found a good technique.  Cool
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    August 2014
Posted by goldhammer on Monday, June 8, 2020 8:04 PM
I've been priming with MM grey laquer primer, scuff prior and after with a grey scotchbrite.  No peeling for me yet.
The scotchbrite is available at most auto parts stores, or can usually beg one from a local body shop.
    June 2020
Posted by JimLo on Tuesday, June 9, 2020 1:19 AM
Ok will do
    April 2004
Posted by Jon_a_its on Tuesday, June 9, 2020 5:45 AM
Badger Stynylrez primer, always, or even just Tamiya as a primer Big Smile or an automotive lacquer primer.
I've always found Vallejo and especially Hataka very twitchy.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
Posted by Tojo72 on Tuesday, June 9, 2020 5:55 AM
Its about the primer. MM acrylics aren't Tamiya neither is Vallejo,they need good primer.Tamiya Etra Fine,or Mr Surfacer,never tried the Badger stuff,heard good things though.
Not lucky,Tamiya not true acrylic more if a hybrid,has very good adhesion compared to those others,especially when thinned with LT
    July 2008
Posted by jeffpez on Tuesday, June 9, 2020 6:08 AM
I always have the same problem with the MM acrylics. I always prime before using them but have never been able to tape over them without some lifting. For that reason I stopped using them whenever masking is required. Once the bottle is opened they frequently start to dry up within a few months which is another reason I now avoid them.
    April 2020
Posted by JBRaider on Tuesday, June 9, 2020 9:41 AM
jeffpez
I have experienced the same problem, the paint lifts even with a primer coat. The only time I will use MM acrylics is if I know that I will not need to mask over them at all.
    June 2020
Posted by JimLo on Tuesday, June 9, 2020 11:42 AM
Thanks. I noticed on my new bottles after wiping the bottle lip clean from paint and closing the lid tightly when I re-open It the bottle lip always has a lot of paint on it from my shaking the bottle. I don't think the lid closes tight enough on the jar to keep the paint from drying out.
Posted by Tojo72 on Tuesday, June 9, 2020 1:10 PM
JimLo
Any jar of paint,you want to be stirring,not shaking to help avoid that problem.
    June 2020
Posted by JimLo on Sunday, June 14, 2020 3:14 PM
I finished my experiment of Vallejo Model Air, Model Master Acryl and Tamiya Acrylic on in-primed and Primed ( with Vallejo Primer) cleaned plastic. After a week of drying I stuck Tamiya masking tape on it and burnished it well. For the unprimed paint the Model Master Acryl peeled off. For the primed paint they were all fine BUT the Vallejo primer with no paint on top peeled right off. So if you use Model Master Acryl you have to prime. If you use Vallejo primer make sure it's a base coat and not a top coat. I think I will stop buying MM Acryl even though they are not being made anymore and invest in more of Tamiya and Mr. Hobby paints. For the primer I might stick with Tamiya and Mr. Hobby too.
    November 2008
Posted by plasticjunkie on Sunday, June 21, 2020 3:35 PM
I wished I had seen this earlier. Acryl over unprimed plastic will peel off unless a solvent primer is used. I hate this acryl  paint and glad I have only 3 bottles. I don't like how it sprays and the adhesion quality is zero.
Tamiya and Mr. Color are fantastic paints specially when Mr. Color Leveling Thinner is used.
 GIFMaker.org_jy_Ayj_O
    June 2020
Posted by JimLo on Sunday, June 21, 2020 4:34 PM
Thanks. I agree. I thought they were good because of the range of colors and how thin they are for airbrushing but if it flakes off so easily I rather use Tamiya acrylics which doesn’t require priming and is more forgiving.
