Tamiya Basic Spray Work airbrush sprays paint even when not depressing trigger?
    June 2020
Posted by JimLo on Sunday, June 14, 2020 4:10 PM
I've tested this on my old and a new Tamiya Spray Work airbrush now and don't know what's wrong. I was spraying Vallejo Metal color ( unthinned since it's already thin) and the airbrush is connected to a Sparmax compressor. once I turn on compressor the paint sprays out even when I'm. Or pulling trigger back. When I do pull trigger back of course it sprays even more paint. Needle is in all the way and not bent. No leaks of paint cup. Compressor hose is attached to an adapter to properly fit the airbrush to the iwata hose. What's going on?
thanks.
fox
    January 2007
Posted by fox on Sunday, June 14, 2020 7:42 PM
Hi Jim! Sorry I can't help you with your problem but I do have a suggestion. If you go to the "Painting and Airbrushing" section of these Forums, you will have a lot of guys there that are very knowledgeable about airbrushes and should be able to help you. Give it a try.
Hope that this helps you.
Jim Captain
Stay Safe.
 Main WIP:
    June 2020
Posted by JimLo on Sunday, June 14, 2020 8:15 PM
Thanks. I just re-posted.
    March 2007
Posted by armornut on Sunday, June 14, 2020 9:42 PM
    Completely clean your airbrush..even things that you think may not be dirty. My Iwata sprayed after ai let off the trigger cause it was dirty. Also check your seal at the brush and make sure you did not roll the "O" ring creating friction between the flow and trigger.
we're modelers it's what we do
