I'm on the same line of thinking as Don and Tojo combined. My hobby desk is actually two very old 26x62 laminate conference / work tables. I buy bulk sheets of white construction board (posterboard) in 24x24 from Hobby Lobby (I believe it is a 10 pack). I also have a small 4x4 and larger 14x14 cutting mat. Usually by the time one build is done, I have glue, paint, knife cuts, etc. on the posterboard so I replace it for each new build.
There are also times during a build where I need to clean (put stuff away) to keep organization of both the build and the supplies. If the work surface is boogered when I put stuff away I will also replace the poster board if needed.
Also during my cleaning I wipe the surfaces down with a spray cleaner and then blow it off with the air from the air brush. If I accidently get paint on my cutting mat I used brush cleaner or thinner to remove it before the next build. This helps get all of the little sanding or scraping slivers away from the builds.
My paints are stored in a large old plastic fishing tackle box. Its many pockets and folding shelves in it allow for a wide range of storage possibilities. All of my brushes are in a carousel brush ends up. I have separate areas for the wide brushes, detail brushes, and dry brushes. My tweasers and speciality tools are in another carousel. Any pliers or cutters, rulers, calipers, scales, etc. are on a specailty tool rack beside the two tables and attached to my wood working bench.
The thing I really need to work on is the organization and storage of hundreds of decal sheets or partials not used on a build. Currently all of my unused decals reside in a large drawer (all scales and subject matter combined).
As long as I'm telling on myself, I also need to organize my scratch build supplies and left over PE. It is difficult skeeping all of this stuff separated for me (plastic sheet, brass sheet, metal rods and tunes, plastic rods and tubes, plastic-struct items, little craft items from model and hobby stores, screen, lead foil), etc.
And my final tell all, I do not have a vented spray booth. My air brush moments are done on the other end of the second conference table (near a window). Some day I will get my act together and build or buy a real vented spray booth.
Ben
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
