I’ve certainly had my trials with “super glue”. My small-but-expensive bottles of Bob Smith Industries extra-thin and gap-filling glue started getting clogged soon after I ordered them, but I did learn some valuable glueing techniques. I figured out the value of putting a small drop of super glue on a postage-stamp-sized piece of cardboard and applying it with a toothpick or something even better, to my mind, the Glue Looper:
The secret of the Glue Looper is the channel that’s near the tip. Put the tip in a drop of thin crazy glue and the channel sucks it up via cohesion. Touch the tip to whatever you wish to glue, and the crazy glue seeps down the channel and onto the part you’re gluing or the part you’re glueing onto. When the tip gets clogged, just burn off the hardened crazy glue with a match or cigarette lighter. The curved tip of the Glue Looper is easy to fit into tight spaces.
The clogging of the Bob Smith glue got worse and worse, to the point I had to use a Vice-Grip wrench to remove the tops. Eventually, I managed to spill each of them. Fortunately, my dining-table-***-work-bench was safely shrouded in a plastic drop sheet on both occasions. Otherwise my wife might have used the drop sheet as a shroud for me!
The second spill was “spectacular”. Nearly all of the bottle of extra-think glue spread out in a large pool on the drop sheet. In attempting to salvage drenched tools, I managed to get a good deal of glue on my fingers, which I was barely able to release before the glue hardened. I spent the next half hour scrubbing my hands with nail polish remover and a stiff brush. For the next two days I had to peel stubborn patches of glue off my fingers and tools. A couple of the tools will never be returned to pristine condition, not that they were in pristine condition before the accident.
Despite my problems with super glue, I’ve found it to be remarkably useful. Several days ago I managed to almost drop my completed Hampden bomber, and in trying to save it managed to snap off the radio antenna, to which antenna wires were attached. But one tiny drop of extra-thin super glue, applied with my Glue Looper, was all it took to invisibly re-secure the antenna.
Another positive moment with super glue came when I noticed that the two halves of the hull of my SS Hope/USS Repose model weren’t coming into contact at the stern, and would never contact once I attached the main deck. So I squeezed them together and touched the seam, from the inside of the hull, two or three times with super glue. Voila! I think it would take an torpedo to tear that stern apart!
I have now purchased two new bottles of super glue, made by Lepage’s. The ridged buttons on each side of the bottle make it easy to release just the amount of glue that you need:
Bob
