Question about modeling and cold temps - Workspace in a garage
    March 2010
Posted by 6stringer on Saturday, January 23, 2021 9:59 AM
Hey all,
I'm thinking about giving my 1st go at a model since I was a kid... 35 years ago. With all the readily avialable tutorials online this seems so much more approachable than the last one I did all those years ago.
Anyways, my workspace would have to be in a garage. Its insulated, but not heated. I live in MN so its cold out there. Never gets below freezing, but its usually around 40-45 degrees out there in the Winter.
I understand that I shouldn't store paints/glues out there, so I will have to pack everything up and move it inside, right? My understanding as the glues/paints don't playwell with colder temps.
Although that seems less than ideal, what about just trying to build/paint in those temps? Is this even worth trying? Will it effect curing/drying times and ultimately lead to poor results? I can always bring a space heater out.
Thanks for all the help!
    July 2004
Posted by stikpusher on Saturday, January 23, 2021 10:34 AM
I’ve been building out of my garages for the past 10 years or so, and painting in them for far longer. Although it really did not get that cold in my non insulated garages during winter when I was working. Yes, cold weather will affect paints and glues in their drying times, so a space heater will help a bit. Storing paints and glues in the cool weather should not be a problem as long as it does not get colder than you listed. But if you’re gonna pack up your paints and glues for inside/outside, fishing tackle boxes are a good option until you accumulate a large amount of paints.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2012
Posted by GMorrison on Saturday, January 23, 2021 11:18 AM
A space heater is a great idea. It's hard to model when your hands are shaking.
Bill
Posted by midnightprowler on Saturday, January 23, 2021 12:43 PM
Cold temperatures would make the plastic more fragile too.
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Posted by Bish on Saturday, January 23, 2021 4:50 PM
While i don't build in my shed, i do my spray painting out there and thats where i store most of my paints, enamels, lacquers and acrylic. Winters tend to be cold (-5c on occasions) and damp. Never had an issue with storing paints, but with some brands of acrylics it can take longer to dry when the air is damp. During winter, i try and spray acrylics on a morning, so usually sat and sun, to give it time to start drying before night.
I store my models out there as well and have not had any issues with the plastic.
    October 2004
Posted by ikar01 on Saturday, January 23, 2021 4:54 PM
When we moved into our place here in Orlando, I immediately took over the garage.  I put down a carpet We broiught with us and made some shelves for the workbench that was in place.  I got some insulation and lined the storage space in the roof and then some heave foam sheets for the walls and the inside of the garage door.  For the cold sdeason I have a heater that looks like one of the old steam radiators I grew up with and when necessary plug it in close to where I will be working. It sometimes gets into the 30s during winter but I keep all my paints and other supplies in the garage, wether the heater is on or not.  Sometimes it gets into the 90s above but I have never had any trouble with my paints or kits.
When it gets cold in your area you might want to get two heaters and maybe leave one on to keep the chill under control.  The radiator types and safer that the heaters with the element exposed.
If you are still concerned about the paints, leave them in the house until you need them.  You can also try leaving some in the grage to see what happens, but unless it hets real cold there should be no paint disasters, especially with one heater going.
    May 2020
Posted by Keyserj on Saturday, January 23, 2021 6:32 PM
I was just out painting a model today in 28-degree weather in Northern Indiana. The cold really makes the drying time slower but so far I haven't had any issues with the paint. I use a rattle can for most of my painting so I am limited to painting out in the yard. I keep my paints inside until I need to apply each coat. When I am ready to put a coat on, I quickly run outside for a few minutes and spray a nice thin coat. Once I get done spraying a coat, I bring the model back into my unheated and uninsulated garage to dry. Temps have been in the teens the past few days but my garage has been about 45-50 degrees Fahrenheit and the model has dried just fine in it. I find it best to paint in the warmest part of the day and to not keep the model out in the extreme cold for more than a couple of minutes. I prefer to keep my paints inside so that they don't become too globby.
"Why don't you knock it off with them negative waves?"- Oddball
John
On the bench:
    March 2010
Posted by 6stringer on Tuesday, January 26, 2021 7:37 AM
Thanks for all the responses. I think I may give it a go and just try leaving them out there when my collection is small. I've left some acrylic house paints out there and didn't have much luck, but could have had just as much to do with age/time rather than cold temps. All paint needs stirring if it sits for awhile. I don't imagine it being much of a problem in the beginning, but if the collection of paint were to grow lugging them in and out seems like a pain. Thanks again!
