Can I use Testors Glosscote/Dullcote on clear parts?
    February 2021
Posted by TheModeler on Monday, February 22, 2021 1:27 PM
Hello All,
I have a car kit that said to put the decals onto the rear window,but the film still shows,so I was wondering wether or not I can use one of Testors Lacquer clearcoats,such as glosscote,for clear parts such as windows?
Thanks,TheModeler(Novice Mode{Just for nowWink})
ON THE BENCH(My first ones):
-1:25 AMT/Round2 1969 Yenko Camaro(40% done)
-1:72 Atlantis Models Bell UH-1B Gunship Helicopter (20% done)
In the stash:
-1963 AMT 1/32 Corvette Stingray
-Tamiya Mitsubishi A6M3 "Hamp" Zero,1/76
-Atlantis Models BELL Firefighter "Old Smokey",1/76
    July 2004
Posted by stikpusher on Monday, February 22, 2021 1:48 PM
I'd recommend something else such as Future as opposed to a rattle can gloss coat. One other suggestion is to trim the decal carrier film as close as possible to the markings before dipping it into the water.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    August 2013
Posted by Straycat1911 on Monday, February 22, 2021 2:22 PM
Instant and permanent look of a sand blasted window if you use GlossCote or DullCote.
Agree with Stikpusher, use Future.
    February 2021
Posted by TheModeler on Monday, February 22, 2021 2:38 PM
Straycat1911
Yes I have heard of Future,but the problem is I don't have an airbrush...
In the stash:
    April 2013
Posted by KnightTemplar5150 on Monday, February 22, 2021 3:13 PM
Future levels out very well on its own. A brush is fine if you don't have an airbrush, just use it straight and in light coats.
    September 2012
Posted by GMorrison on Monday, February 22, 2021 3:26 PM
Holding the part by a corner thats not clear, like the frame; touch the other corner to a piece of paper towel to wick off excess, and avoid bubbles. I much prefer that to airbrushing Future, something I don't like to do.
 Also not sure if that will solve your problem. If the decal is "silvered", it's a bigger issue.
Bill
    April 2020
Posted by Eaglecash867 on Monday, February 22, 2021 4:15 PM
Future is best applied to clear parts by dipping or by brush.  Airbrushing it usually doesn't go well for clear parts, so no need for an airbrush to apply it.  Like Straycat said, definitely don't use either Testors clear coat on clear plastic.  They're both lacquers and they will permanently craze the clear plastic.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    December 2020
Posted by TheDemiGod on Monday, February 22, 2021 5:42 PM
Eaglecash867
I've dipped & hand brushed Future on clear parts. I also airbrushed Future through my airbrush with zero issues as well. Check out this kit I recently finished. Yes, I airbrushed it with Future....
Posted by Don Stauffer on Tuesday, February 23, 2021 9:03 AM
Straycat1911
True with Dullcoat, not true with Glosscoat.  I have often coated transparencies with Spray Glosscoat.
    September 2006
Posted by the Baron on Tuesday, February 23, 2021 11:58 AM
Just to be...clear, too, the product is now called "Johnson's Pledge with FUTURE Shine", in case you have to go looking for it.  But we all still call it Future, since that's what it was for years.
I use it for transparancies, like windshields or airplane canopies by dipping.  For gloss-coating before decaling, I usually brush it on, which works just fine.  I have used the airbrush to apply it, though, too.  I have brushed it unthinned, and also thinned 50/50 with water, just to see.  In the end, it's easier to clean a brush after applying it.
If you get drips that cure, you can just take a little dilute ammonia solution (like Windex) and apply it to the drip with a brush or a cotton swab (mindful of not getting fibers in the finish).  That will dissolve it, and you can wipe away excess as necessary, and just let it dry and cure again.
