Crossover of photo etch parts
    March 2021
Posted by black widow on Friday, March 19, 2021 1:48 PM
Hi all. I have been wondering if anybody has had any luck using the "aftermarket" photo etched and other goodies available on a brand of kit  they weren't  designed for. For instance I have a 1/48 scale  Fujimi Messeschmitt bf110 kit  I am itching to do. External detail is pretty nice and the parts seem to line up ok, but I notice its pretty slim on good detail. Wheel wells, and landing gear are especially bland.  Cockpi is so-so.  I am sure theres tons of aftermarket parts available for a BF110,  but of course they arent going to be for  a fujimi kit. I am not expecting a bolt in fit up, but is it something I might pull off with some massaging?  Thank You,  Neal Zimmerman
Posted by Bish on Friday, March 19, 2021 3:15 PM
It can be done, i've done it myself a few times. few things to keep in mind. The kit your doing may have slightly different dimensions (smaller/bigger) than the kit the AM was designed for. So there may be slight gaps or bit might need trimming to fit, things like IP's especially. If your useing a PE set, it will give the numbers of the kit parts to be trimmed/replaced. The PE set might not ad/replace everything you might want it to as the kit it was designed for might be more detailed and some bits might not need replacing.
It just need's a bit more thought putting into it and double checking everything.
fox
    January 2007
Posted by fox on Friday, March 19, 2021 3:20 PM
I've only used PE that comes with a kit or AM seatbelts. I'm 80 and the eyes and hands won't let me work on that stuff. I'd like to but maybe in another life.
If you go to the airplane section of the forums you will probably get the answers to your question. The members who post there usually use a fair amount of PE in their work.
Hope you get the answers you're looking for.
Jim Captain
Stay Safe.
 Main WIP:
Posted by gregbale on Friday, March 19, 2021 8:50 PM
I do it all the time...chiefly because I rarely build the 'state of the art' kits that most P-E is designed for, and more often want to add detail to old Airfix, Frog or Revell kits and the like.
Generally there are very few fit problems except for instrument panels and cockpit consoles; there the forethought Bish mentioned is an absolute essential. Panels often need to be trimmed (or the areas where they fit 'enlarged' via judicious hacking or grinding away too-thick plastic walls with files or a Dremel). All of which is much easier to do at the start, rather than when exacting cockpit-detailing is finished and then you realize the blasted part won't fit!
[Ask me how I know that.... Bang Head]
Greg
George Lewis:
Posted by Don Stauffer on Saturday, March 20, 2021 8:59 AM
Often.  Sometimes I even use it on other genre.  For instance, gratings are a common object on many different models.  Ladders are generic.  In fact, PE manufacturers sell generic sets of rails and ladders for various popular ship scales.
    April 2020
Posted by Eaglecash867 on Saturday, March 20, 2021 9:09 AM
Not quite the same thing, but very similar...I'm adapting 3D printed decals from Quinta Studio to fit an aftermarket resin cockpit.  They were made to be used on the kit parts.  It definitely can be done with a bit of ingenuity and elbow grease.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
Posted by Rob Gronovius on Saturday, March 20, 2021 4:15 PM
There are probably as many correct answers as there are photoetched parts. I've had some that will not be suitable for another kit and some that fit right in without a problem.
And some kits live lives in another company's box so what will work for an original might work just fine in a retooled reissue.
    March 2021
Posted by black widow on Saturday, March 20, 2021 10:04 PM
This is good news. I was hoping it might work, Gonna give it a shot . That Messserschmitts wheel wells really need some love,
     Neal
