You can also use Bondo spot putty from the auto parts store.
Don't be surprised if it shrinks a bit while you get used to the proper thickness to lay it on.
Also, if you have access to Evergreen Sheet Styrene, you may have good results from filling gaps with a thin strip of plastic, leaving you with a much smaller gap to be filled with putty.
God luck
Rick
