One big part requires different sheens for each section.
    January 2021
Posted by Teenage Modeler on Monday, June 14, 2021 2:18 PM
How do I separate a different sheen of clear coat for a different portion of the same part?
Here is an example:
I glued the engine block in one piece. The block is not supposed to be in one sheen, but 3 different sheens of clear coat (gloss, matte, semi gloss).
How do I separate each portion of the engine, for a different type of sheen?
I'm guessing that you should mask the parts that don't have the sheen.
Made you Look
    September 2012
Posted by GMorrison on Monday, June 14, 2021 2:36 PM
Teenage Modeler
Correct as usual, King Friday.
Bill
    January 2021
Posted by Teenage Modeler on Monday, June 14, 2021 4:12 PM
GMorrison
Teenage Modeler
Bill
Made you Look
    April 2015
Posted by Mopar Madness on Monday, June 14, 2021 7:13 PM
Could be a little time consuming but you're exactly right. Just mask the portions you need kept as-is.  Then spray your next sheen. Let that dry for a few hours, mask it, then spray the third sheen.  It will look great when it's finished. Just needs a little extra work.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
