Sanding grits? I can't find them
    January 2021
Posted by Teenage Modeler on Monday, June 14, 2021 8:17 PM
I went to my local home improvement store, and went to the sandpaper section. The highest grit that I found was 1000 grit. But, I know that it is a little rough when polishing scale models.
Where do I buy very high grit sandpaper (or sanding sponges, around 2000-8000 grit range)? I was thinking Amazon, but any stores that have it?
Made you Look
    April 2013
Posted by KnightTemplar5150 on Monday, June 14, 2021 8:23 PM
Most auto parts stores will have finer grades of sandpaper in stock. Also, check your local Hobby Lobby for micro-mesh sanding pads.
    August 2014
Posted by goldhammer on Monday, June 14, 2021 8:25 PM
Most auto paint stores will have wet/dry from 1500 to 2000.
fox
    January 2007
Posted by fox on Monday, June 14, 2021 8:34 PM
Try Megahobby, Squadron and Sprue Bros are just a few. Check a copy of FSM for their advertisers page. Model Car Magazines should have the same thing. Micromark and Model Expo also have all types of sanding supplies.
Hope that this helps.
Jim Captain
Stay Safe.
 Main WIP:
    January 2021
Posted by Teenage Modeler on Monday, June 14, 2021 9:39 PM
KnightTemplar5150
Okay, will do!
Made you Look
Posted by keavdog on Monday, June 14, 2021 11:36 PM
Thanks,
John
    November 2008
Posted by Justinryan215 on Tuesday, June 15, 2021 12:11 PM
goldhammer
Dont forget about the 3M Trizact 3000 grit!
I hear amazing things about 'Super Sanding Blocks' from Goodman Models....
"...failure to do anything because someone else can do better makes us rather dull and lazy..."
Mortal as I am,I know that I am born for a day.  But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the Earth...
    April 2020
Posted by Eaglecash867 on Tuesday, June 15, 2021 2:35 PM
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    September 2006
Posted by the Baron on Tuesday, June 15, 2021 4:49 PM
fox
Jim Captain
Stay Safe.
Second that, Jim!
    June 2021
Posted by rocketman2000 on Wednesday, June 16, 2021 7:32 AM
Although I have bought finer grits at Hobby Lobby, if I want to polish with something finer than 1000 I go to polishing compounds.  If you use polish it is important to use a wax-free polish if you will be painting that surface later. Toothpaste is a polish that you probably have.  Talcum power is a very fine polish- mix it with a little water.  There is another very fine polish material- rouge, but it leaves a red stain on aeverything than metal but is a great metal polish.  One advantage of polish and soft cloth is that it conforms well to surfaces better than sandpaper.
