Wet sanding is work and it takes time. Work slow and be patient. Tape off corners and raised edges as you can burn through the paint super fast when wet sanding and ruin all your work. I use sanding pads that go from 3000-12000 grit in a soap and water setting. When you are done sanding you can polish with various types of polish to get that perfect shine. I use Novis polishes for this. Here is a video that should help.
Here a my Chevelle I did using this method. It looks great after all the wet sanding.
Good luck,
BK
