How to create this design ?
    August 2021
Posted by arcturus87 on Monday, August 28, 2023 9:39 AM
Hi
This is a 1/8 Pontiac. I need to re-create this below the belt line body contour/crease . Does anyone have any ideas how I cand  it please ?
The reason is I want to turn this wreck in an Esprit, so need to cut the wheels flarings off. That will then leave me with a triangular shape missing so need to resume the body lines . 1/8 Pontiac . by Modelmadness, on Flickr" target=""> 1/8 Pontiac . by Modelmadness, on Flickr
    October 2019
Posted by Tanker-Builder on Monday, August 28, 2023 12:25 PM
I Hope this Helps!
    You will have to do this, As I did years ago on this same model. Cut off the wheel flare all around the wheel lip.Take thin strip Evergreen that matches the thickness of the fender! and restore the thinner part of the wheel opening. Then take thinner strip and create a backing for the next step.
    Take Evergreen plastic the thickness of the body and put it in the upper and lower places allowing them to overlap at the crease and make sure the outer edge of the crease is filed at an angle to match the Contour. Fill lightly and wreck away. Take the end of the flare and let it hang off or whatever. Viola! one messed up wheel flare. Use more of the thin strip to hang off around the top over the fill piece you put in.
        Oh, I am sorry, I mis-understood what you said.You want to turn this into an "Esprit" Okay, using the parts I told you about. That's how you restore the wheel openings.The bottom part when done as I said with fill used, will conform back to the body shape. Funny! My "Esprit" had Fender Flares!(Must've been a dealer Thing!) Oh and I could only get it in a Deep metallic Wine color then. Later they came in Gold and Blue too I think! The Hood Scoop bump was offset to the side as well.
      There was a "Bird " on the hood BUT, it was smaller and only on the Scoop ("Bump") I think these things were regional dealer items too!
    January 2010
Posted by CrashTestDummy on Monday, August 28, 2023 3:36 PM
Wow, that IS a messed up kit!  As a former owner of several second Gen Pontiac F-body cars, I can verify that indentation that goes along the lower 1/2 of the side of the car doesn't exist in reality.  It's one curve from the belt line to the pinch weld.  As Tankerbuilder said, though, cut the flare off, leaving the trailing edge for the rear wheel well opening, and replace it with thin styrene sheet.
There were certain 'Esprit' trim packages that had those flares.  IIRC, the 'Bluebird' was one such trim package (kind of a powder blue body color with the flares and I think a firebird decal on the hood.
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
