Model Instructions
    November 2023
Model Instructions
Posted by Martyhh on Monday, December 4, 2023 1:05 AM
I was wondering if people had thoughts on which manufacturers provide the best set of instruction with their models.  Particularly aircraft.  I've found that sometimes it's hard to follow what the manufacturer is trying to tell you in a particular step.  Thoughts?
Posted by Tojo72 on Monday, December 4, 2023 1:01 PM
Tamiya are pretty good,but really none are perfect and contain errors,you really need to work your way thru them and figure out the best course if action.Many times you shouldn't even follow the manufacturer instructions,you need to figure out when to assemble and when to paint from your own experience.
    September 2006
Posted by the Baron on Monday, December 4, 2023 2:16 PM
Martyhh
Top of the line is probably the companies like ICM, Eduard, Dorawings, the now-defunct Wingnut Wings, and probably others I've left out, whose instructions on some of their ranges of kits, or even their entire catalogs, are almost comparable to publications like Squadron's "In Action" or "Walkaround" series.  Photos, text, as well as exploded drawings for each step of construction, diagrams of sprue layouts, extensive illustrations of the subjects you can finish the kit into, and similar information.
But those makers' kits are also more expensive than other brands' kits. Quality generally costs more.
You've missed out if you're younger than say, 40 years. Back in the day, companies like Monogram and Revell put a lot of thought into their instructions.  Kit instructions not only showed the parts and a build sequence, but usually named the part itself. So you learned about the subject as you built it.  Monogram used to apply a user test to its instructions. They invited kids to come in and build first-run issues of the kits, and the instructions, to help identify where they could be improved.
But eventually, most companies wound up reducing the info to the least amount they felt necessary, thereby reducing the cost of producing instructions.
Then there are instruction sheets from the 60s, 70s, 80s, 90s, and even today, from companies overseas, with poor English translations, often humorous, too.  And you should see the instructions in kits from eastern Europe, especially Russia, from the 80s and 90s.  Often a single sheet, just an exploded drawing, maybe text, maybe translated.
As Jim notes, you develop some experience, too, and find after a while that you don't necessarily need to follow the instructions exactly, in every case.
    April 2020
Posted by Eaglecash867 on Monday, December 4, 2023 2:37 PM
Its looking like Zoukei-Mura's SWS series kits have some of the best instructions I have seen to date.  Assembly diagrams for each step, with each step's assembly diagram being accompanied by painting instructions as well as a color photograph for each.  I'll be building one of their kits for the first time, and managed to find some photos of the instructions in their official build log.  They're like nothing I have ever seen.  Amazingly detailed instructions.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    July 2004
Posted by stikpusher on Monday, December 4, 2023 3:01 PM
I think that some of the best aircraft kit instructions that I've come across are those that came in the Pro Modeler issue boxings of Revell Monogram kits. They had photos of actual aircraft detail areas such as cockpits or landing gear, as well as detailed explanations of colors or other minutia related to the assembly step.
But instruction sheets overall tend to vary quite a bit depeding upon the era in which they were printed, as well as by company. Accurate Miniatures made great kits, but their instruction sheet illustrations looked almost hand drawn on some kits. Trumpeter's instructions can be good for a laugh in some translations.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2006
Posted by the Baron on Monday, December 4, 2023 6:04 PM
stikpusher
I think that some of the best aircraft kit instructions that I've come across are those that came in the Pro Modeler issue boxings of Revell Monogram kits. They had photos of actual aircraft detail areas such as cockpits or landing gear, as well as detailed explanations of colors or other minutia related to the assembly step...
Stik, you remind me of the Revell/Monogram boxings that included Detail & Scale books, too: the 1/32 F4F (originally Revell), and the 1/48 TBD (originally Monogram). I had already built those kits when they were released, but I bought those post-merger releases just to get those books.
    July 2004
Posted by stikpusher on Monday, December 4, 2023 8:27 PM
the Baron
stikpusher
I have a few of those myself. Come to think of it, the Pro Modeler instructions that had the photo references I believe were done with the assistance of Bert Kinzey from Detail & Scale.
       - Plankton
LSM
    September 2006
Posted by the Baron on Tuesday, December 5, 2023 9:02 AM
Yes
