Right Angle Gears 5/8" Shafts
    December 2011
Posted by model make on Monday, January 29, 2024 11:45 AM
Hi
Thought we would ask here since everyone is so knowlegable
They might be called mitre or bevel gears
Have a nice day
Bob
We would like mild steel or cast iron
Plus on the large or overkill side
About 3" outer diameter. 1/2-3/4" thick
    August 2005
Posted by EdGrune on Monday, January 29, 2024 3:11 PM
Grainger Industrial (grainger.com) offers bevel gears in brass, stainless, plastic(?) with 15mm / 5/8" bore.  Check online catalog, put gear into search box
    December 2011
Posted by model make on Monday, January 29, 2024 9:46 PM
Hi Ed
Thank you.
Guess we are thinking like it is like the nuts and bolts bins at a NAPA
We just look at them and grab the two we want.
This is not a now project.
We are just happy we figured out how to do it.
Have a good evening
Bob
    August 2021
Posted by lurch on Monday, January 29, 2024 10:38 PM
What are you trying to make or repair?
    December 2011
Posted by model make on Tuesday, January 30, 2024 2:39 PM
Hi Lurch
Something like this:
https://kingmidgetcarclub.org/trainer/
Actually bigger.Same general type  of car though.
So load on gears is chassis and an adult.Not two little kids like that one.
Then the engine stress would be a 2 or 3 horse lawnmower type engine.
It is going to a jackshaft though so it is not so much of a load.
Lot of reduction with jackshaft and axle sprocket.
NOTE Engine is up front and sideways.
Then driveshaft is dropped down low with two sprockets and a chain.
Have a nice day
Bob
    August 2021
Posted by lurch on Wednesday, January 31, 2024 3:47 AM
Ok Is there a reason why the engine is in the front? What is your ultimate goal here? I was fortunate to ran 5 go kart tracks for 19 years and worked on many of them and alsoother types of karts. I may be able to help you out..But not sure what you are trying to accomplish..
    December 2011
Posted by model make on Thursday, February 1, 2024 2:09 AM
Hi Lurch
It is like a 3/4 scale car.
Built with kart components.
Have a nice day
Bob
Will post Paint drawings.
    December 2011
Posted by model make on Saturday, February 3, 2024 1:52 PM
Okay.Maybe this will clear things up.
Using 4 bolt rims.Which go up to 13" rims & tires.
We have the 4 bolt pattern front & rear hubs.Spindle hubs and ones to fit 1" axle in rear.
Will do our best to get Paint drawings done.
Bob
    August 2021
Posted by lurch on Sunday, February 4, 2024 12:45 AM
You may wantto consider moving the engine to the rear. It will be cooler for both the driver and the engine. There  is a company that manufactures and sells commercial grade karts. It is called Formula K out of Michigan. They may be of  some help also. What kind of clutch system are you using?
    August 2021
Posted by lurch on Sunday, February 4, 2024 12:47 AM
You may want to also consider using the engine size to 5 to 7 HP.
    December 2011
Posted by model make on Tuesday, February 6, 2024 12:57 PM
Hi Lurch
Sorry it took awhile to get back to you.
We will stick with front engine for this project.
Actually it is the whole point of it.
How to build a front engine lawn mower engine powered kart car?
We have solved it.
The pair of bevel gears is the solution.
Going into a jackshaft and axle structure.Which is sort of a 'differential'.
Being you can change gear ratios.
So the 'driveshaft' from the engine to the jackshaft can be 1 to 1.
Have a nice day
Bob
These popups make for a hard post.
    September 2012
Posted by GMorrison on Tuesday, February 6, 2024 1:24 PM
model make
Yes they do.
For any post more than a sentence or so long, I've begun to type my post in Word and paste it into the reply. Saves a lot of frustration.
Bill
    August 2021
Posted by lurch on Wednesday, February 7, 2024 1:50 AM
Model make , I get the idea now. I am very curious how this comes out.I do hope you post some pictures of your project.
    August 2021
Posted by lurch on Friday, February 16, 2024 10:38 PM
So , have you made any progress on your project?
