Recommendation for color of cannons/engine nozzles on Jedi Eta-2 Starfighter body color or gray?
    April 2010
Posted by Mustang8376 on Thursday, June 20, 2024 10:19 AM
Greetings everyone, I am in the process of building Revell's Jedi Starfighter which did not come with a color guide.  The current color I am using is Steel so it has a metallic sheen.  So would the surrounding cannons/engine nozzles be the same/similiar color or some version of gray?
Current build: 1/48 Monogram A-1H & AMT Jedi Starfighter.
Completed:  1/48 Monogram/Revell P-61B, 1/32 Hasegawa F6F-5, 1/48 Hasegawa F-16C, 1/48 Revell Mig-21PFM, 1/48 Revell/Monogram AH-64A, Revell/Monogram 1/48 F-14D, AMT 1/420 USS Defiant, AMT 1/650(?) USS Enterprise, 1/72 Bandai VF-1J, AMT 1/537 USS Reliant, Academy 1/35 M1-A1 Abrams, Academy 1/48 F-86F30, Linbergh's USS Gato
    May 2020
Posted by learmech64 on Friday, June 21, 2024 7:44 AM
Mustang, The beautiful thing about Science fiction is its not real so no one can say its the wrong color. Your model, do as you wish.
Doug
    January 2021
Posted by JoeSMG on Friday, June 21, 2024 8:03 AM
I'd go with the Amazon stock picture for reference - it looks pretty sweet.
Check out the cockpit controls - some leds back there with some drilling would also be pretty cool :)
- Joe the SMG
    April 2010
Posted by Mustang8376 on Friday, June 21, 2024 10:48 AM
Thanks everyone.  I believe I found a gray to go for the cannons and then I will be adding the purple since I will be basing this on Mace Windu.  I was just trying to determine if it was looking too metallic.  I will try to get an image when I come back from my trip.
    March 2022
Posted by missileman2000 on Saturday, June 22, 2024 8:30 AM
I suspect a gunmetal gray would be fine.  No oxygen or nitrogen in space so no oxide or nitride stains.
Posted by Rob Gronovius on Saturday, June 22, 2024 11:00 PM
There are several reviews of the Revell kit here. There are painting suggestions by the builders/reviewers.
https://www.starshipmodeler.com/starwars/starwars_ships.htm
