QUOTE: Originally posted by Bob Raymount
Hello all again.
Could anyone in Oz please point me in the right direction for a supplier of reasonable quality display cases for 1/48 aircraft? I have been searching for some time and have not come up with anything.
Thanks in advance for your time.
Bob
Bob, most of the cases that look half decent and totally protect your model have to be ordered from OS.
It would be easier and cheaper to make your own, as I do.
I simply get a piece of 9mm MDF (Medium Density Fibreboard) from the local hardware store and have them cut it to the size I require.
Then I get the local glazier to bang together a perspex cover to suit the size of the MDF.
I prefer perspex as I fear glass getting broken. But glass would be cheaper.
I use the thinnest perspex I can, usually 3 mm.
Now if you want them to be nice and flash cases, then you can also purchase edging for the base, which you cut to size and glue on, then stain any colour you want.
The BV-141 in my sig is on a custom base I made, and a piece of mirrored perspex is on top of the MDF.
All up, this case cost $50 to make, may seem a little pricey, but it will last forever, and I know that the model inside it will not get dusty or damaged.
Proof is, last year at our local show, my 1/48 A-10 Warthog was on display as first place winner, the BV-141 got a special mention, and someones 1/32 Zero fell of it's stand and landed smack bang on top of my A-10.
If it wasn't for the strength of my case, the A-10 would have been stuffed.
