Assistance with finding an adhevsive
Posted by Anonymous on Saturday, May 22, 2004 4:10 PM
I am about at my wits endSad [:(] In attempting to build another diorama I have come up with a situation where I am attempting to join a piece of sheet styrene to a material similar to that which whiffle balls are made ofDisapprove [V]
I have tried TenX7, super glue, epoxey, household super cement and contact cementDead [xx(] I have roughed up both surfaces, tried it with smooth surfaces and the results are the sameBanged Head [banghead]Banged Head [banghead]Banged Head [banghead] With this particular problem I feel as if I am dumber than dirtConfused [%-)]
Any help will be greatly appreciatedBig Smile [:D]
Richard
    January 2004
Posted by MusicCity on Saturday, May 22, 2004 6:19 PM
Epoxy should have worked, that stuff will stick anything to anything. I presume both parts were very clean before they were glued.
1) Try some stuff called "Shoe Goo" available at KMart and other department stores. I used to use it a lot on R/C cars and it will stick anything to anything (just like epoxy is supposed to!). I've used it on Lexan, graphite, aluminum, just about anything you can think of. It is VERY thick though so that might cause a problem.
2) Would it be possible to go some route other than glue? Stupid as this sounds, perhaps stapling?
3) Could you just use vinyl tape and tape them together?
    October 2003
Posted by rebelreenactor on Saturday, May 22, 2004 10:26 PM
Have you tried CA glue?
John
Posted by Anonymous on Saturday, May 22, 2004 11:02 PM
Whiffle balls? That's PVC, right? Try plumber's glue; the stuff that sticks PVC drain pipes together.
Good luck,
Bruce
    May 2003
Posted by qmiester on Sunday, May 23, 2004 10:24 PM
If it is the plastic I think it is (can't remember its name) even Shoe Goo won't hold to it. It's almost like teflon, slick and even paint won't adher to it. (I have a 8"x8"x1/4" piece that I use to hold my body putty when I'm applying it - when I'm done, just let putty dry and then slide it off). You may have to consider using a mechanical means of fastening it together (staples, screws, nuts & bolts etc).
Now I'll probably stay awake half the night trying to remember its name!
Quincy
Posted by wayne baker on Monday, May 24, 2004 10:02 AM
Would you consider two sided carpet tape? Does it have to be glue?
 I may get so drunk, I have to crawl home. But dammit, I'll crawl like a Marine.
Posted by Anonymous on Monday, May 24, 2004 4:09 PM
Quincy may be onto something; if it is UHMW (ultra-high molecular weight) plastic, which is a high density polyethylene, then you are SOL.
Sorry,
Bruce
Posted by Anonymous on Monday, May 24, 2004 10:09 PM
try drilling a hole, and another hole, then putting in a pin and about a pound of superglue
try roughing surface, filling it in with bondo, and then supergluing
    January 2004
Posted by MusicCity on Sunday, May 30, 2004 9:40 AM
Waitaminute! HDPE is commonly used for natural gas and water lines, and they typically use a thermal welding process to connect pipe sections. Perhaps just using a soldering iron to carefully "Weld" them together would work. Not sure what kind of fumes it would give off though, so a respirator might be a good idea while you try it.
Posted by Anonymous on Sunday, May 30, 2004 2:13 PM
Good idea Scott, except he wants to attach the HDPE to Styrene. I don't know if HDPE solvent cement will work on styrene either.
Other than a mechanical fastener, I think he's pooched.
Regards,
Bruce
Posted by Anonymous on Sunday, May 30, 2004 3:12 PM
I want to thank all of you for your help. What I finally did was to take the material I couldn't stick anything to and using sheet styrene made a duplicate shape which worked out fine. Once again, Thanks.
Richard
Posted by Anonymous on Sunday, May 30, 2004 7:09 PM
Rats ...
Now we'll never find out what sticks to the material that nothing stick to!
Glad you found a solution Richard,
bruce
