Clean lines
Clean lines
Posted by Anonymous on Wednesday, April 16, 2003 1:45 PM
What is the best thing to use for masking an area to achieve a sharp, clean line after painting?
Posted by Ray Marotta on Wednesday, April 16, 2003 3:11 PM
I always use automotive masking tape. For a REALLY sharp, clean line,
cut strips of tape with a new #11 blade using a metal straightedge as a guide.
To prevent paint from bleeding under the tape, burnish it down real well or,
spray some clear along the tape edges and let it dry before shooting your color coat. There's bound to be different and possibly better ways to get the results you want, This is just one of the many.
Ray
Posted by naplak on Wednesday, April 16, 2003 3:29 PM
I use Tamiya masking tape. If I need a really sharp edge, I cut it on a glass plate.
Using Bare Metal is good too!
www.naplak.com/modeling ... a free site for modelers www.scalehobby.com/forum/index.php ... a nice Modeling Forum
Posted by Anonymous on Thursday, April 17, 2003 12:32 PM
Thanks guys. I was thinking of trying the Bare-Metal. I hadn't thought about about sealing the edges of masking tape with clear.
Posted by naplak on Thursday, April 17, 2003 12:35 PM
I don't think th eclear tape would help... another choice is to get Scotch Drafting tape... art and drafting stores would have it. It is masking tape with have the adhesive. It sticks well enough for painting, but pulls off easy -- I only recomment this if you are air-brushing light coats tho...
The Bare Metal will leave some residue behind, but it is easy to wipe it off.
Posted by Anonymous on Friday, April 18, 2003 12:30 PM
i think he means clear coat...
Posted by Anonymous on Friday, April 18, 2003 1:11 PM
Yes. Clear coat.
    January 2003
Posted by Keyworth on Saturday, April 19, 2003 4:19 AM
You might try low-tack masking tape (the blue stuff). It has worked well for me. -Ed
"There's no problem that can't be solved with a suitable application of high explosives"
Posted by Anonymous on Saturday, April 19, 2003 12:12 PM
i use painters mate green the thin one cause its cheap and not much else...
Posted by Anonymous on Tuesday, April 22, 2003 1:33 PM
It depends on what you want to mask, for large areas such as camo patterns I also like the low tack painter's tape, the blue stuff. It comes in several widths, and unless you burnish it with a ton of force it wont lift off the paint underneath it.
To mask canopies, I prefer bare metal foil. Sure it leaves a residue, but it comes of easily. And BMF is so easy to cut canopy frames out of.
Hope that helps,
N.
