Space heater in garage...safe?
    January 2004
Posted by knight667 on Monday, September 20, 2004 10:50 AM
Hello all! I do all my modeling in our garage, which is a detached building from our apartment. In the winter, it tends to get pretty darn cold; last winter I suffered through by wearing multiple layers and my old army watch cap...I survived, but barely. Big Smile [:D] Anyway, I was considering a small space heater, but I'm not sure if it's a good idea. The garage isn't that big (about 25' long by 15' wide) and while I try to ventilate it well, I'm sure that fumes aren't moving as well as they should (I *do* wear a respirator almost all the time, certainly when I'm airbrushing).
Anyway, anyone else have any experince with space heaters and this sort of situation?
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
Posted by Anonymous on Monday, September 20, 2004 11:25 AM
Ah Ha....a fellow garage dweller! As I live about 300 miles due North of your position and have set up camp in the garage, I know your scenario. I too have considered using a space heater, but I'm worried about blowing myself up by having a igition source so close to my work area. What if I accidentially knocked over a can of paint thinner? BLAMM!!!! I'm BBQ! Dead [xx(] The thought kinda scares me. [:0]
I think I'm going to wall off and insulate my little corner of the garage and tap into the house's ducting, since my garage is attached to the house. I don't know about space heaters and the mere thought of solvents,.... and I have a lot of them. I try to error towards the side of caution whenever possible.
    December 2003
Posted by scottrc on Monday, September 20, 2004 11:43 AM
Two things, lots of "space", say three of four feet at least, and second, NO AIRBRUSHING WITH SOLVENTS! You'd look like a McDonalds french fry thats stuck on the fryer basket too long if those vapors cause a flashover.
Now, what I did was let the heater run for a few hours BEFORE I worked, then shut it off to paint. That way you will still have a few hours of toasty without being toasted.
Scott
    December 2003
Posted by scottrc on Monday, September 20, 2004 11:51 AM
Oh yea, and don't store you paints out there if its getting below 55 degrees for long periods of time, then you warm up the place, then let it get cold again. Large variances in temperature is hard on both acrylics and enamels.
    July 2003
Posted by diggeraone on Monday, September 20, 2004 12:16 PM
John,if I was going to use a space heater I would keep it at least 15 to 20 feet away from my work area.This also depends on what type it is,electric or gas.If it is gas at least 25 feet away and that is according to the HAZ-MAT giude book that I use as a driver when I work with hazzardous materals.If it is electric I would get a big one and high it from the rafters by chain.Do this in a corner that is out of the way and let it drop about a foot and a half from the rafters,secured by chains.With this set up you can use a stand up fan which will help curculate the heat and also help with ventilation of the room.Digger
Put all your trust in the Lord,do not put confidence in man.PSALM 118:8 We are in the buisness to do the impossible..G.S.Patton
    January 2003
Posted by ADleitch on Monday, September 20, 2004 4:21 PM
Fort Drum has stopped use of all space heaters, especially gas powered following the death of a number of soldiers At Ft Bragg last year. The fire guard fell asleep due to monoxide posioning, which inturn killed the rest of them in the tent, which is about the same size as your garage.
Just something to think about.
If you are getting a headache or funny taste in your mouth while working in there, turn the thing off and get out.
Its Better to Burn out than to Fade Away!!!
    January 2004
Posted by knight667 on Monday, September 20, 2004 4:42 PM
Thanks for all the input! Sounds like this winter I'll be wearing multiple layers while I'm working. Just safer. Thanks again!
    July 2003
Posted by lizardqing on Monday, September 20, 2004 10:26 PM
You could always consider one of those oil filled radiators. Not quite as efficent, but no open heat source.
    January 2003
Posted by paulnchamp on Monday, September 20, 2004 10:40 PM
I work in a basement which gets pretty chilly in winter, and for the past three years I've been using a kerosene heater. They are illegal in some states (not here in RI) but it does a good job. It's a somewhat drafty basement, so I get some fresh air infiltration, and I don't do any airbrushing with it on. It works well, has never caused any problems and without it, model building would come to a standstill for several months and . . . and. . . I'd slowly go insane. . . Dead [xx(]Disapprove [V]
Paul "A man's GOT to know his limitations."
