need info about styrene
Posted by Anonymous on Tuesday, November 23, 2004 2:57 PM
I need to tap into this pool of wisdom. I am doing a custom build of some equipment i work with. It's going to be a tough build, but with you guys help I think I can fake it till I make it. Anyway, i was reading through FCM and saw an add for "Super Styrene". I am trying to "simulate" Square tubing, such as a body frame of a cargo tralier or something like that. I have never used styrene, and I was wondering if some of you guys could point me in the right direction as to the proper use of it, and how it is used. Im not clear if it is easy to form and shape. And once formed, is it still plyable? What about painting, which paints should I stay away from? Im not really sure about this styrene and I was looking for help.
Thanks guys
Posted by Anonymous on Tuesday, November 23, 2004 2:58 PM
Oh yeah sorry i forgot, if anyone wants the web page that the styene is on it's:
www.midwestproducts.com
Posted by ckfredrickson on Tuesday, November 23, 2004 10:35 PM
Your questions are a bit broad, but I'll give it a shot anyway...
Styrene for the modeler comes in a couple of forms. Often it's already been injection molded to resemble a plane, tank, or car, and put in a box. For those of us who care to scratchbuild, we buy extra strips or sheets (also preformed; see the catalog at the link you attached to see some of those available), and cut them up for use as we see fit.
The properties of these materials are somewhat size dependent. For example, thin pieces (0.010") have a stiffness comparable to construction paper or manila folders, while thicker pieces (0.040") can have a stiffness comparable to the cardboard on the back of a notepad.
If all you're going to do is flat sides/straight sections, just get the plastic, cut it to size, and glue it up. If you're going to need to do curved rails, then things start to get tricky... thin plastic may hold it's shape or be bent easily, but thicker pieces may need to be heated (not melted), shaped, and then allowed to cool.
Likewise, if you want to do curved side-panels, you may have to carve masters and vacuum form, a la the 2nd link below:
A relatively simple project: http://www.briansmodelcars.com/tutorials/tutorial.asp?TutorialID=32&CurPage=1
A more complex project: http://members.aol.com/GCGassaway/vacuform.htm
Evergreen Styrene and Plastruct are the more common brands I've heard of, but the stuff you've mentioned will also work. My personal preference is to go to the hobby shop so I can eyeball the stuff before I buy it, but that's not always an option.
Basically, a lot can be done with styrene, though it's usually a matter of time and patience.
Painting - I would recommend enamel or acrylic based paints. Some use lacquers (usually auto builders), but they're pretty nasty and require some extra processing.
Posted by Anonymous on Wednesday, November 24, 2004 2:18 AM
one of the things I will use the styrene for is in making a frame, sqare tubing. I will not need sheets, or flat sections of it. I will be contructing a chasis frame, or something similar to that. Once molded, or glued together, to itself, is styrene hard like plastic?
    July 2003
Posted by Foster7155 on Wednesday, November 24, 2004 2:55 AM
Styrene isn't like plastic, it is plastic.
You can purchase styrene premanufactured in sheets, tubes, squares, I-beams, box beams...just about any shape you can think of and in just as many sizes.
Robert Foster
Pensacola Modeleers
    July 2004
Posted by Lt. Zogg on Wednesday, November 24, 2004 10:40 AM
Fhound,
Check out this book, it should tell you most of what you need to know about working with styrene. I found it very helpful when learning to kitbash and scratchbuild stuff.
http://www.hobbylinc.com/htm/evg/evg14.htm
Jeff
Posted by Anonymous on Friday, November 26, 2004 1:17 PM
hey thanks again guys, some good links.
