Paint Removal on Old & Extremely Rare Model
Posted by Anonymous on Wednesday, March 30, 2005 8:29 PM
Hello Everyone,
I am a new member to this forum, and I have a question right off the bat. I recently purchased an extremely rare styrene model of a spaceship that was manufactured in 1962. It is in very good shape except that it is painted the wrong colors. I might add, that it looks like it was painted by a child because the paint is applied very thick in some places and not very well. My intention is to restore this model and the first step in that process is to strip off the old paint without damaging the plastic. What is the best way to do this? Does anyone have any suggestions on what to use and where do I get it?
Also, I would like to try and salvage the original decals. Is there any good way to get them off of the model, preserve them, then rejuvenate them when I am ready to re-apply them? Any suggestions or help would be greatly appreciated.
    August 2004
Posted by Tankmaster7 on Wednesday, March 30, 2005 8:59 PM
the paint can be stripped using brake fluid or oven cleaner. I diubt the decals can be saved.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    August 2004
Posted by jdavidb on Wednesday, March 30, 2005 10:29 PM
for this model being so rare, I'd like to say that brake fluid should not be used because it is brutal stuff. If it's the wrong kind of plastic, brake fluid can cause it to crumble.
It's hard to say what to do without being able to see the model and its paint. Sometimes you can chip off old paint without using any chemicals at all. I'd try that first.
Oven cleaner is mild. You just spray it all over the painted areas, close it up in a plastic bag or other sealable container for around 10 hours.
The next step up in harshness is nail polish remover. You've gotta sit there with the parts while they soak and keep testing the paint. Get the paint off and get those parts out of the nail polish remover as soon as possible. Nail polish remover is acetone that is weakened by the other stuff in it. So, don't use straight acetone. Use nail polish remover. Acetone will eat plastic fast.
Posted by Anonymous on Thursday, March 31, 2005 11:51 AM
Thanks guys for your help and advice. I will probably try the oven cleaner first. I spent quite a bit of money for this model so I definitely want to start on the conservative side.
Posted by wayne baker on Thursday, March 31, 2005 11:56 AM
Welcome to the forum. Besides using the paint on type of oven cleaner, i've had success using Castrol Super Clean. It's available at the many marts. Let the parts soak in it if you can, or spray it on.
 I may get so drunk, I have to crawl home. But dammit, I'll crawl like a Marine.
Posted by upnorth on Thursday, March 31, 2005 2:27 PM
Isopropyl alcohol my friend. Available in most well stocked drug stores and pharmacies.
Find a plastic container just a bit bigger than the model's all around dimensions so that the model will go in comfortably but not leave too much extra space.
place the model in the container and pour in the alcohol straight from the bottle over top of the model until the bottom of the container is completely covered in alcohol.
Fill the container with hottest tap water (do not use boiling water from a kettle) to fill the container the rest of the way until the model is submerged completely or as much as possible and then put the cover on the container loosely. Do not push the lid down to seal it, you just want to keep things warmer longer and slow down the alcohol's evaporation rate a bit.
Place the container in an out of the way spot away from ignition sources and let it sit overnight.
The next day, take an old toothbrush and give the model a scrub with it. the paint should be softened enough that you can get some of it off.
I find this method works well with both enamel and acrylic paints. As your model is no doubt painted with enamels, you may have to repeat the process a few times before getting all the paint off.
The alcohol will not damage the plastic at all and if there are clear parts it wont craze them.
All around its just safer for your health and your model. It may not be the fastest stripping method mentioned here, but think of the extra time involved as extra piece of mind.
Good luck in your project.
    June 2003
Posted by gbarnes on Thursday, March 31, 2005 5:26 PM
Hi Direland,
I collect lots of old models, and am curious about what you bought? I found an Aurora Lockheed XFV-1 in a box of junk, and stripped and restored it using alcohol. Repolished the canopy with toothpaste and was very pleased with the way it turned out. No way to save the decals, so scrounged from other kits, and used Chartpack rub-ons for some of the numbers. Good luck with the restore.
Gerald
PS- Click my profile; there's a picture of my pride and joy rocket!
Posted by Anonymous on Thursday, March 31, 2005 8:17 PM
I use simple green if there are any questions to the condition of the plastic. It is totally safe, but takes maybe a bit longer. I usually just soak my parts in it for a couple of days, and then scrub it with an old toothbrush. Oven cleaner and brake fluid is great if you are in a hurry, but it sounds like you want to treat it with a bit more care. Good luck, and welcome to the group!!
Posted by jhande on Tuesday, December 27, 2005 5:42 PM
Sorry guys, but I have to wake up this subject again.
I don't have a rare model, but do have one that needs repainting.
It's a recent AMT plastic 1/25 scale auto, sprayed with many coats from a can of testors  semi transparent enamel.
My son and I want to respray it again the same color, it came out bad the first time around.
We want to save the raised letters and emblems that are part of the plastic model itself, so the safest chemical stripping is preferred.
I would assume, either the Simple Green or alcohol bath methods would be safe?
Simple Green is used 100%?
Alcohol to water ratio? Or does it really matter as long as I dilute it?
And they really loosen the paint?
Gee, I better be careful next time I clean the wifes car LOL. Big Smile [:D]
-- Jim --
"Put the pedal down & shake the ground!"
    August 2005
Posted by eizzle on Tuesday, December 27, 2005 8:22 PM
The easiest way to strip a new model is going to be soaking in brake fluid. Find the cheapest stuff you can, and pour it in something that will cover most, if not all of the model, then cover it, and make sure its covered good, cause those fumes can be pretty bad for you. Brake fluid seems to soften the plastic a little, but nothing that is going to eat away any lettering or make it so bad that you can't work with it, in fact the thing I have noticed about it doing this is it tends to give a little more when you are sanding on it than before, but its nothing thats going to hurt it! Good luck J!
Colin
 Homer Simpson for president!!!
Posted by jhande on Wednesday, December 28, 2005 1:39 AM
Thanks eizzle...
The cheapest brake fluid you say, uhm...
Guess my wife will be using the snowbank to stop at work tomorrow.
Did I say that? Shock [:O]
Wink [;)]
-- Jim --
    August 2005
Posted by eizzle on Wednesday, December 28, 2005 8:46 AM
 jhande wrote:
Thanks eizzle...
Wink [;)]
Wow, don't use my name when you talking like that! I don't want anything to do with it Mischief [:-,] Then again, if she just has to use the snow bank, it shouldn't be tobig of a deal, as long as she doesn't try to stop head on with itLaugh [(-D]
Colin
Posted by jhande on Wednesday, December 28, 2005 3:53 PM
Don't worry eizzle, your name won't come up in the accident report. Wink [;)]
Not to worry, she's getting to be an old pro at using snowbanks, she spins around and either backs into them or parks sideways on them. She always seems to keep the nose clean.Shock [:O]
Actually I'm just kidding...
I'd buy new brake fluid and leave the old dirty stuff in her car. Big Smile [:D]
-- Jim --
Posted by grandadjohn on Sunday, January 1, 2006 12:47 PM
Floquil(parent compant is Testors) also markets a product for paint and decal removal called ELO, can be a little harsh on plastic but it does work. May be alittle more expensive than some of the other items mentioned here.
Posted by jhande on Monday, January 2, 2006 1:47 AM
Thanks for the tip John. Wink [;)]
-- Jim --
