Bud, use white glue for canopies...works like a charm.
IronBrigade, depending on what you use for rigging, I've found that surgical silk works the best. I've found the key to rigging is to cut a length of line far more than you need, anchor it on one end, let it dry, then pull it tight, attach with CA and a drop of kicker. The key is getting a solid anchor point first.
Jeff
