Display cases (or should I say boxes)
    March 2005
Posted by Aviator on Monday, May 9, 2005 7:13 PM
I see that there are other posts about display cases, but my question is a little bit different. My Idea is to hang most of my planes from the ceiling and put my favorite ones in some kind of clear enclosure (so I can look at it and keep the dust off at the same time). I would like something about the size of my plane, a 1/48 fighter; you know, small enough to put on a table or desk. I suppose that someday when I have alot of "favorite ones" (and the room) I'll need a trophy case kind of thing. But for now, I'd like something small. What should I use and where can I get it?Question [?]
Posted by Anonymous on Monday, May 9, 2005 7:18 PM
Look thru the newspaper, or browse garage sales for used aquariums.
You can then use clear plexiglass for the lids.
Your case can also be lit with aquarium lamps, but test the case with a thermometer to check how hot it gets with the lights on.
Dont want to melt your kit.
Posted by Anonymous on Wednesday, May 11, 2005 4:56 PM
got any 1/2" or 3/4" plywood ?
cut you the size that suits you and what you want to display........
get yourself some wood trim molding.........take your pick, especially if you're near Lowe's or Home Depot (Go Tony)..............'
attach the molding along the base of desired plywood thickness and determinate size flush along the bottom of the wood piece...........
now's the tough part........where i was in Dallas there was a company that made custom acrylic / lexan tops to go on my homemade bases.........
company was called Contemporary Designs in Grand Praire.............
gave 'em the 3 ID dimensions and in less than 10 working days i had a display case.........the base of which you can make into what ever melts your butter.........a dio..........tarmac..............field........etc....etc........
hope this helps and i do realize you might not be near any where that makes acrylic or lexan tops to fit your ID's...........but, maybe this'll give ya head start on something that DOES suit ya...........
best 'o luck Aviator...........
Posted by wibhi2 on Wednesday, May 11, 2005 5:34 PM
You can still hang them and put them in a clear enclosure to keep dust off. You can do this any one of a number of ways, but I'll give you 2 easy ways to start your head rolling - okay 3
1.) In a plastics shop or online look for (2) .04 thk or thinner clear (styrene or acetate) hemispheres just a bit bigger in diam than your AC. rigg 1/2 to hang from ceiling and your AC - then glue or clip on bottom half.
2) build a clear plastic diamond and hang like above
3) For desk top - go to http://www.rollmdels.com and look up the imex cases. they are cheap and come in a variety of sizes
3d modelling is an option a true mental excercise in frusrtation
Posted by Anonymous on Sunday, May 15, 2005 11:05 PM
Aviator your LHS should have display cases of various sizes for sale.
Tamiya makes them also but I never seen the locally at any LHS here in Vancouver, Canada.
    March 2005
Posted by Aviator on Monday, May 16, 2005 8:42 PM
Thanks for your help. I plan to put alot of work into my Wildcat, so I want to protect it. With all the resin and PE I'll be using (I hope it turns out OK) I'll want to be able to admire it without having to dust it.Big Smile [:D]
    January 2005
Posted by jinithith2 on Monday, May 16, 2005 9:06 PM
how do you hang it from the ceiling?
    March 2005
Posted by Aviator on Tuesday, May 17, 2005 8:27 PM
Well, for 1/72 fighters I used something clear like fishing line. I cut a piece (length is kind of arbitrary) and tie the ends together so it is a big loop. Then place the loop under the wings. After that, I bring the ends of the loop over the wings. Now the plane is hanging by the fuselage.
That's just a big rubber band, the fishing line doesn't show up.
Under the wings...
and now brought over the wings. I then wrap the end around a thumb tack (or the like) and stick it in the ceiling.
This is one of my older models that doesn't get much attention, that's why its so dusty.
I just kind of made this up and I like it. It allows you to position the plane in different ways. You can have it climbing, going into a dive, or banking to the left or right. But now that I am getting into 1/48, I'm not sure how I'm going to hang them. With the 1/72 I have never had one fall down, but the 1/48 probably will require more than just a tack.Big Smile [:D]
This is how I've done it, but I'd love to see how others do it.Wink [;)]
    November 2003
Posted by Copterguy on Tuesday, May 17, 2005 8:29 PM
I buy premade boxes at my LHS. They are manufactured by Imex (I think that is how it is spelled) and they come in a variety of sizes to suit 1/48 aircraft, 1/35 armor, etc. They are completely made of clear plastic so there is no big metal or wood frame to obsure viewing. They are also stackable. I get the ones with the clear bases. Whenever i finish a kit, i buy a box and in goes the kit. Never have to worry about dust. Check their website to see what they look like. Here is the link:
http://www.imex-model.com/displaycases1new.htm
Jim Smile [:)]
Current Projects: Tamiya M1A2 Tamiya LRDG Chevrolet CWT 30
    January 2005
Posted by jinithith2 on Tuesday, May 17, 2005 10:04 PM
my LHS has some of them but they over price waaaaaaay too much.
    March 2005
Posted by Aviator on Wednesday, May 18, 2005 1:08 PM
I know, sometimes I think I could make something for less than what it costs to buy the pre-made kind. Even though you could custom build your own, it would be a lot easier just to buy one. But I'd rather spend the money on the modelBig Smile [:D]
I don't know. I guess if I find one that I like and is not overpriced, maybe I'll buy it.Sigh [sigh]
