1/87 Scale AAAAAAAAARRGGGHHHHH!!!
Posted by Anonymous on Wednesday, June 25, 2003 3:09 AM
Some one help me please! how and what is the formula when measuring in 1/87 scale? For example 35 feet would be what in 1/87 scaleDead [xx(]
    January 2003
Posted by leemitcheltree on Wednesday, June 25, 2003 4:36 AM
Joe,
The scale (eg. 1/87) simply means that the percentage of reduction from the full size item is 87 times. If the model is 1inch long, then the full sized item would be 87 inches long or 87 times larger than the model. Or rather, the model you have is 87 times smaller than the original.
We work here (in Oz) in the metric system (soooooo much easier than Imperial measurement) and it's really easy to figure out a scale difference between the model and the original -
If a full sized item is 900mm long, a 1/87 scale model would be 10.3mm long - that's just taking 900 and dividing by 87.
It's really very simple - even I can figure it out................
Cheers, mate
LeeTree
Cheers, LeeTree
Remember, Safety Fast!!!
Posted by MikeV on Wednesday, June 25, 2003 9:30 AM
LeeTree is right.
First convert it to inches:
35 feet x 12 inches = 420 inches.
Then divide it by your scale size:
420 inches divided by 87 = 4.83 inches.
Easy isn't it? Wink [;)]
Posted by Anonymous on Wednesday, June 25, 2003 11:48 PM
As I said to Lee Tree it's usually the simple things that get's looked over....Thank you both for your quick response....That was simple.
Posted by djmodels1999 on Thursday, June 26, 2003 2:03 AM
Here's a scale chart for you to use...
http://www.wwi-models.org/misc/scalecon.html
Have fun!
