Best putty brand for plastic models?
Posted by Anonymous on Sunday, August 7, 2005 11:03 AM
What is the best putty brand for filling in holes and seams on plastic models?
Thanks,
Danny
Big Smile [:D]
Posted by Anonymous on Sunday, August 7, 2005 11:30 AM
This is a very opionated question.
My favorite is ModelMaster because it gives you plenty of working time, thins easily with liquid cement for small gaps, easy to see where you are putting it on any color of plastic, and it still dries within a half hour. However it is a very toxic putty and can be bad for the health if misused. It is lacquer based.
Posted by Anonymous on Sunday, August 7, 2005 11:34 AM
I like Squadron green-Testor's is the worst.
Posted by Anonymous on Sunday, August 7, 2005 1:02 PM
I can never get Squadron green to go on smooth. I follow the directions but it still finishes very rough even after sanding.. help?
Posted by Anonymous on Sunday, August 7, 2005 1:36 PM
Pnawrocki-have you tried the white?
Posted by Anonymous on Sunday, August 7, 2005 2:13 PM
I use Bondo Glazing and Spot putty. This is the best stuff that I have found. The drying time is about 20 mins. and you can shape it and smooth it as needed. I get all of mine from Wal-Mart and auto parts stores. The item # is 907, Try that and see what you think.
Posted by grandadjohn on Sunday, August 7, 2005 2:18 PM
I used Squadron green myself, but for small cracks and seams I use CA
Posted by Woody on Sunday, August 7, 2005 2:46 PM
I think this is one of those unanswerable questions. You need to find out what is best for you in a give application. I use Squadron Green & White, Aves Apoxie Sculpt, Bondo Glazing and Spot putty, CA in various thickness and with fillers like baking soda, and my own homebrew putty http://www.finescale.com/fsm/community/forum/topic.asp?page=1&TOPIC_ID=21787
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
Posted by Anonymous on Sunday, August 7, 2005 5:36 PM
I always liked this stuff by 3M called "Acryl blue" or something like that - it's an automotive finish putty, so you'll have to look for it at autobody/paint supply stores. It's very fine-grained, doesn't crack, and can also be thinned and smoothed with Testors liquid cement. It sands easily and takes on the same texture as the adjacent plastic. I never liked the Squadron green putty. Acryl-Blue It comes in a fairly large tube, and should last you for a long, long time. (It will probably dry out in the tube before you are able to use it all up).
Brian B.
    July 2004
  • From: ...Ask the other guy, he's got me zeroed-in...
Posted by gringe88 on Sunday, August 7, 2005 6:28 PM
the green stuff always dries goopy for me. i mean when i try to sand it comes off in chunks and gets stuck to the stick
====================================== -Matt
Posted by Anonymous on Sunday, August 7, 2005 9:20 PM
Thanks for all the replies. I'm new to modeling and really didn't know which brand to buy or which was the better application. Again thanks to everyone for the input.
Danny
Posted by tigerman on Monday, August 8, 2005 5:33 PM
The white is all I use.
 Eric
    July 2004
Posted by tho9900 on Monday, August 8, 2005 9:14 PM
I use both squadron green and white... green for big jobs... white to either cover the green (finer grain) or to fill small gaps like at wing roots... it sands smoother than the green and is less lumpy...
Posted by Anonymous on Sunday, August 14, 2005 6:39 AM
Ah ok so the white is for finer grains. I gotta try that because the green (even after much sanding when completely hard) comes out very grainy and rough. Thanks!
Posted by Anonymous on Friday, August 19, 2005 7:39 AM
the 3m stuff (red or green) seems to shrink a lot. therefore, more than one coat must be applied.
    July 2003
Posted by zokissima on Friday, August 19, 2005 9:09 AM
Squadron white putty works well for me.
    September 2004
Posted by Abdiel on Friday, August 19, 2005 12:42 PM
Although I'm a relative newbie to modeling, I've used Aves Apoxie Sculpt for years with my metal sculptures and have found that it works great with my models as well. It smooths out well with water and is drilled and sanded easily too.
Good luck!
Eric
    August 2004
Posted by Tankmaster7 on Friday, August 19, 2005 7:11 PM
My favorite is a weird acrylic water based glop i picked up at a contest. It smooth out with water, and sands completely smooth with wet sanding.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    September 2004
Posted by Abdiel on Monday, August 22, 2005 11:42 AM
So Tanky, when we ask for it at the hobby store, will they automatically know what we want when we ask for the "Weird acrylic water based glop"? Wink [;)]
Posted by Jim Barton on Monday, August 22, 2005 5:53 PM
I use a tree-sealing product called "Doc Farwell's Seal n Heal" as a modeling putty. It's used for sealing pruning wounds after removing branches, but it's not the usual black stuff (Seal n Heal is water-based and tan colored). It does shrink when it dries (which I try to use to my advantage by putting on more than necessary), but it sands nice and smooth and accepts enamels beautifully. I've only seen it in California; it may only be a local product over there, but the jar I have has lasted me several years and I still haven't made a dent in it.
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
    September 2004
Posted by Borg R3-MC0 on Wednesday, November 16, 2005 1:52 AM
I like Tamiya putty, it has a fine grain and can be thinned with nail polish remover.
    October 2005
Posted by Kolschey on Wednesday, November 16, 2005 6:55 AM
One material I tend to use is a putty called Modeling Paste, made by Liquitex. It is used in acrylic painting as a thickener, or as a means of building up a painting and facilitating texture. It's consitency is that of a sort of thick peanut butter, and it comes in a default white color, though it can aslo be mixed with acrylic paint in order to color it. Once dry, it is very strong, and can be sanded to a very smooth consitency. You can find it in just about any art supply or craft store.
If you have any less-than-favorite incomplete projects, it might be worth picking up a small jar just to experiment with. Even if it doesn't meet your needs on the model itself, it definitely will work nicely for creating terrain effects. Smile [:)]
Krzysztof Mathews http://www.firstgearterritories.com
Posted by Anonymous on Thursday, November 17, 2005 12:09 AM
i use the Tamiya "Fast" curing putty. sandable in 2 mins under direct flourescent light and a minute under direct sunlight. after this i follow it up with Mr.Surfacer for an unbelievable smooth finish!
    July 2005
Posted by clairnet_person on Thursday, November 17, 2005 9:53 AM
I use Tamiya basic for big stuff and CA for the little things and even white glue sometimes.
Current builds: Monogram P-40B Revell F-15E
Posted by Anonymous on Thursday, November 17, 2005 10:18 AM
Lots of good ideas in here.  Hard to say what is "best" but here are my top 5 anyway
1 - squadron green/white
2 - bondo red
3 - elmers white glue*
4 - elmers wood glue
5 - five minute epoxy
*elmers works surpriizingly good, sands down nice and can be simply washed off if you dont like it
Posted by Anonymous on Saturday, November 19, 2005 5:28 AM
I use Tamyia Basic Type Putty, works fine for me...
Stay away from Revell Plasto ! I attacks the plastic very fast ! Only positive thing about Revell Plasto is that it sands very smooth !
Cheers,
Jürgen
