warped clear parts
warped clear parts
Posted by Bossman on Thursday, July 17, 2003 9:36 AM
I'm finally finishing an Airfix 1/72 Westland Seaking. Don't usually do helo's but I thought that this was one of the coolest subjects I'd seen in a while. The kit has been great except for one thing. The front windshield (do they call it a canopy on a helicopter ?) is warped so that it doesn't fit properly onto the body. Can clear parts like this be heated up in hot water and bent back into position ? Any other ideas ? I don't want to screw this up - the rest of the model turned out great.
Thanks !
    June 2003
Posted by allan on Thursday, July 17, 2003 9:44 AM
Hey there, Bossman. What a coincidence, I'm building a Seaking, too.
Im not too sure about heating up and bending clear parts. The last time I did some bending on clear plastic (with and without heat) it left a gazillion tiny cracks that made the canopy look scoffed. If the warping is not too bad, may I suggest you make the fuselage conform to it instead. Why not ask for a replacement part from Airfix?
No bucks, no Buck Rogers
Posted by Anonymous on Thursday, July 17, 2003 12:11 PM
THe clear stuff is a thermoplast, just like the rest of the kit (i.e. if heated, it flows. Resins are thermohardners. If they're heated, they set). I suggest take a bit of the sprue the windshield is on and use the ol' warm water treatment on it. That way, if the plastic doesn't react too well to the treatment, then you know this material isn't suited for it.
    January 2003
Posted by leemitcheltree on Thursday, July 17, 2003 9:07 PM
Bossman, I'd be very surprised if you could heat and then bend the canopy without leaving hundreds of tiny stress fractures.
I'd first try to get a replacement from Airfix before messing about with the original screen.
Good luck
LeeTree
Cheers, LeeTree
Remember, Safety Fast!!!
Posted by gregers on Friday, July 18, 2003 11:25 AM
Hi Bossman. Have you thought of molding a new conopy? just get a small piece of 1/4 ply (about 6"x6" will do) fill the kit canopy with with plastercene /bluetack or whatever you have as modeling clay stick a bit of sprue in it to use as a handle cut a hole in the ply the same shape as the canopy but slightly larger so it will just fit through pin some clear styrene sheet to the ply then warm it in the oven untill it goes slightly soft (taking care not to burn yourself as this stuff gets very hot) then take it out then push the canopy through the hole so it is just clear of the ply and hold it there for a few seconds then remove the kit canopy and cut around the new one and admire!!! . you may have to do a few to get one just right but it will look loads beter than the kit offering and will easily bend to fit the fuselage. ho and very lightly grease the canopy that you use as a plug mold to aid removal. Hope this helps...Greg Cool [8D]
BTW I have built two airfix seakings (both USN and RAF) and both canopys didn't fit...Greg Angry [:(!]
Why torture yourself when life will do it for you?
Posted by Bossman on Tuesday, November 11, 2003 11:58 AM
Just wanted to THANK YOU guys for your input.
MAN ! 4 months before a reply !!!!!!! Sorry - my modelling proceeds at an equally slow rate.
Anyway - she's done - and turned out good. If I do another one (And I think I may) - I'll take your advice gregers. I wound up getting impatient and I used a different method. I noticed that the part was off by about the width of a hacksaw blade. I wound up cutting a width out of the piece just inside one of the center braces (that way it would still be symmetrical). I glued it with white glue and I have a hard time seeing the correction. So I'd say it was a success.
I don't frequent the forum all the time - but I've learned alot whenever I have. Thanks again for the advice. If I get hold of an e-camera soon, I'll include a pic.
Posted by Anonymous on Tuesday, November 11, 2003 3:20 PM
Too bad its over... I would have said buy a replacment from squadren, if they make one.
