How do you "Dry" your Models?
Posted by Anonymous on Tuesday, October 25, 2005 10:21 PM
i just wanted to ask you guys how you dry or "let cure" your models in between coats?(primer,basecoat,topcoat,wash...etc.) do you leave it to dry in side a cabinet to protect against dust? or leave it out in the open?(but what about the dust?) which method makes it dry better or properly to safely continue to the next step of painting?
    August 2005
Posted by Frunobulax on Tuesday, October 25, 2005 10:58 PM
I just leave mine "out" on the desktop. Most airbrushed paint, topcoats, Future etc. dries to the touch in few minutes. Dust isn't really a problem, unless it's in the airbrush. I always clean mine out before I paint. Now, when I dip a canopy in Future, I will put an upturned bowl or something similar over the piece. I usually let my models dry at least 24 hours before going to the next step. Some glossy paints might need a little longer, but flat colors dry almost as soon as the spray hits the plastic.
Edward "I guess he's about the best dang sergeant they is in the whole dang Air Force." Join the FSM map http://www.frappr.com/finescalemodeler
    May 2005
Posted by Bgrigg on Tuesday, October 25, 2005 11:02 PM
I have a large spray booth with lexan doors. It's sealed well enough that if I turn the fan on when the doors are closed it slows down the fan. I leave the models in the booth until they are dry to the touch.
So long folks!
Posted by Anonymous on Wednesday, October 26, 2005 1:26 AM
I let mine dry on the paint stand and leave the spray-booth switched on to extract fumes and dust.
Posted by rjkplasticmod on Wednesday, October 26, 2005 9:39 AM
I let mine dry in the spray booth until dry to the touch, usually about an hour unless it's gloss enamel. Then I move it to the bench where I let it cure for 24 hours minimum. Dust isn't a problem in my work environment.
Regards, Rick
Posted by Anonymous on Wednesday, October 26, 2005 9:50 AM
i let mine sit in my paint booth till it's dry to touch. then i set it aside for at least 24 hours and work on something else.
    December 2003
Posted by scottrc on Wednesday, October 26, 2005 11:10 AM
No matter where I put it, whether it be in a dust proof box or left out on the bench, with three dogs and a cat, a hair is bound to get attached to the model.
    May 2005
Posted by Bgrigg on Wednesday, October 26, 2005 12:00 PM
Ha! With three dogs and a cat the hair has infiltrated your paint in the sealed jars!Big Smile [:D]
So long folks!
    January 2005
Posted by jcheung5150 on Wednesday, October 26, 2005 3:06 PM
I use a domed plastic, transparant cover that you get when you buy a cake at the supermarket. its usually wide and tall enough to fit most of my models. just put the model on my desk and place the dome on top of it.
Jimmy Photobucket
Posted by Anonymous on Wednesday, October 26, 2005 3:36 PM
I am pretty much bald and keep my remaining hair closely cropped-so imagine my chagrin when I purchased a hairdryer and suffered the teasing at check out. But at low speed it does a great job of drying paint or clear coats
    May 2005
Posted by Bgrigg on Wednesday, October 26, 2005 4:26 PM
You should have said it was a gift for your many models and left it at that!
So long folks!
Posted by Anonymous on Wednesday, October 26, 2005 5:23 PM
Bill-I don't think they would have 'bought' that! Although a few years ago I was dating someone (not that interesting) and let a weekend pass without calling her. She called me and coyly asked how I had spend the weekend. I said-with a model. She asked where I had met her. My answer: At a hobby shop (actually Chuck Yeagers' Bell ride). End of story and relationship. Hee-hee!! No smooches for me.
Posted by Anonymous on Thursday, October 27, 2005 6:57 AM
Thanks for the replies! and the cool story dan!
