Amodel kit’s or generally hard, especially if you never built any limited run kit before, but they’re not impossible. I built there Bf-109Z and it was tough. Every single part needed to be clean and refurb, none of parts fitted correctly or even close, the Plastic was extremely brittle. I even had to reshape the wings and the fuselage under hot water to get them straight. After all that I finally got started on the actual construction of the kit
. There was a lot sanding (went through more then 1 sheet of sandpaper). As for gaps they were many. It questioned me if one tube Squadron putty will fill in all the gaps
Here are some pictures of her…
I did it in a winter camo scheme to show that it was used in Eastern Front.
I beat brains into complete submission with this kit and never built/started a kit after 6 months completing this one. Strange thing is once I started building again, I decide to undertake a Tamyia kit and gave up on it. Everything fitted perfect and it just made it really boring for me. Now I’m collecting up limited run kits to build instead the usual well-known brands
