aftermarket parts
    July 2013
aftermarket parts
Posted by DURR on Saturday, December 17, 2005 10:27 AM
when i am looking for  a resin this or p/e that
every one i look at says for hasagawa this tamiya that etc
 in theory  scale should be scale
 soooo
1/48 scale resin cockpit set for a fw190a should fit anybodies even if is says for a certain model
i would like to know from everyone  the whats whys  and why nots
thanks
    June 2005
Posted by MontanaCowboy on Saturday, December 17, 2005 5:29 PM
Well, when a certain manufacturer sets out to build a model, they first find a its real-life counterpart, and take its measurements. There is not just one airplane that everyone measures and gets the exact same measurement, they measure different ones, and nobody is perfect. Some people may measure a rebuilt one, or go on ducumented measurements. This causes variation between models. AM products may be for just one model because of this. Some will fit 2 or more kits, though. And some AM parts will need modification. I would never let my money ride on a cockpit set, That is the LEAST likely to fit more than one kit. Hope this answers your question. SO YES, if scale is scale, then it would all fit, but it doesn't, there are far too many variables, thickness of plastic is just one, as well as the overall shape. Plus, nobody is perfect.
"You know, Life is like a Rollercoaster. Sometimes you just die unexpectedly." No wait, that's not it.
    August 2005
Posted by eizzle on Sunday, December 18, 2005 11:26 AM
Sign - Ditto [#ditto] Sometimes companies have a bad habit of including parts from older kits, even thought the new kit is supposed to be a more advanced model, i.e., the RM F-14 D, from what I have heard, it still has the same back contol panels as the F-14A and that is supposed to be diffrent. I am sure there is a lot more of this going on, but sometimes it doesn't show up, until you go to use a PE set and it doesn't fitBlack Eye [B)]
Colin
 Homer Simpson for president!!!
