DRY FITTING
DRY FITTING
Posted by Anonymous on Sunday, August 3, 2003 9:50 AM
is it important to dry fit all the peices of the model before you glue it together?
    January 2003
Posted by shermanfreak on Sunday, August 3, 2003 9:54 AM
I think so .... it certainly beats trying to pry the 2 pieces apart if the fit is terrible. On some kits I've found that other pieces sometimes get in the way of joining 2 major pieces together and need to be adjusted.
Posted by Anonymous on Sunday, August 3, 2003 10:27 AM
Dry fitting is one of the most basic fundamentals of this hobby. Dry fitting and a little sanding as needed saves a lot of filling and sanding.
Darren
Posted by Anonymous on Sunday, August 3, 2003 11:08 AM
Building a model without dry-fitting is like doing a crossword puzzle with a pen.
Posted by midnightprowler on Sunday, August 3, 2003 11:40 AM
Ditto all of the above!
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
    January 2003
Posted by paulnchamp on Sunday, August 3, 2003 8:20 PM
I know how important it is, but for some reason I usually remember it AFTER I've applied the glue! Blush [:I]
Paul "A man's GOT to know his limitations."
Posted by Anonymous on Sunday, August 3, 2003 8:44 PM
I always dry fit...yeah, right. Blush [:I] I always try to remember to dry fit but I can't remember my ginko (that's the stuff that helps memory, right?). Tongue [:P] Dry fitting can save a lot of work so I do it as much as I can.
I use a pen for crosswords too. Big Smile [:D]
    January 2003
Posted by leemitcheltree on Sunday, August 3, 2003 8:58 PM
Junkman,
All the folks who've replied tell the truth. Dry-fitting is very important.
It can make the difference between a model that looks like crap and a model that you can be proud of.
When you dry fit the bits, you can check and see just how well the bits fit - or how poorly the bits fit.
By finding this out, you can determine just how you need to "massage" the bits so they DO fit properly - by either trimming by knife, filing, or sanding. It can also show if you need to use filler to fill gaps.
Cheers,
LeeTree
Cheers, LeeTree
Remember, Safety Fast!!!
Posted by RAF120 on Sunday, August 3, 2003 9:45 PM
Yes!
Trevor Where am I going and why am I in this handbasket?
Posted by Anonymous on Sunday, August 3, 2003 10:54 PM
Junkman,
Read my post about this build (it's about the fifth down) and you will see why it's important. I would not have found these problems in time without dryfitting.
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=5817
    January 2003
Posted by Keyworth on Monday, August 4, 2003 12:04 AM
Dryfit, dryfit, dryfit. I probably "build" my kits at least three times before I ever touch the CA or my airbrush. Keeps you from going "Oh #$&*" somewhere down the line. - Ed :)
"There's no problem that can't be solved with a suitable application of high explosives"
Posted by berny13 on Monday, August 4, 2003 8:44 PM
I am a believer in dry fitting. As said above, it will save many hours of extra work. The only time I ran into problens with dry fitting was on the Tamiya F-15E in 1/32 scale. The parts fit so good that when I dry fitted them I couldn't get them apart. Most I just left that way without applying any glue.
Berny
 Phormer Phantom Phixer
On the bench
Posted by tigerman on Tuesday, August 5, 2003 9:59 PM
I guess I'm an oddball, I don't dry fit much at all. Clown [:o)] I usually do if I question the fit, but usually I wing it. Since most of the models I build are Tamiya made, they usually fit together without much problems. Hey these kits take long enough to build as it is! Angry [:(!]
 Eric
Posted by Anonymous on Sunday, August 10, 2003 10:18 PM
Merlin - I do the crossword puzzle every day in pen ! But I ALWAYS dry-fit. What's that the old carpenter used to say ? "Measure twice - cut once." Makes sense to me.
Posted by Anonymous on Monday, August 11, 2003 3:48 AM
So that's where I've been going wrong!
I've been doing it the other way around all these yearsSmile [:)]
Posted by Anonymous on Monday, August 11, 2003 7:38 AM
Hey merlin ! Its gotta be that Maine air ! I lived in Freeport ( 1961 - 68 ), and built my first models there. I never dry fitted anything until I re entered the hobby !
Posted by dubix88 on Monday, August 11, 2003 7:47 AM
HEY,
Listen, i live in Maine and even tho the air sucks, lol, i still dry fit. Now, if he is a MAINA, that would explain alot of things, ayah it would.
Randy[:-p]
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
Posted by Anonymous on Tuesday, August 12, 2003 5:41 AM
I DO dry fit, I do. I spend moah time dry fittin' than gluin'
I don't do crawswuhd puzzles tho cuz I cayahnt spell.
I'm nawt a bawn Maina, I just live heeah now cuz I like lobstah a lawt.
Posted by Anonymous on Tuesday, August 12, 2003 8:05 AM
Touche Merlin ! ! ! Give that man a cigar !
Posted by wibhi2 on Tuesday, August 12, 2003 6:08 PM
Ibid to all the above - If I am going to screw something up, I like going into it knowing full well that I am going to screw it up
3d modelling is an option a true mental excercise in frusrtation
    January 2003
Posted by stinger on Tuesday, August 12, 2003 7:13 PM
Dry fitting is second nature to me. I think it all started as a kid. My mother would take me to buy a model, and, me not being able to wait to see what it looked like, I'd start putting it together on the way home in the car (C'mon guys, we've all done that). I'd be holding so many parts together with my little hands that when I finally let go, they'd all just fall together back into the box. Sometimes I'd have to search the floor of the car later for a missing part. I still feel like that little kid when I dry fit now, but I do it for different reasons and I'm A LOT more careful about part numbers! (And, well, ok, I still can't wait to see what it looks like). It has proven to be a valuable part of building something nice, and getting a "preview" of potential problems, rather than the "Oh #!@ !!" (quote from Keyworth) results of just going for it.
And as Darrenbb has said it is one of the fundamentals of building.
Claymore - You know that as we get older, memory is the second thing to go. I can't remember the first.
May an Angel be your wingman, and the Sun be always at your six
Posted by wibhi2 on Wednesday, August 13, 2003 11:07 AM
Don't forgrt the second carpenter's rule (walkin' on thin ice here)
"Flat as a board and easy to nail"
with all those 10 pennies stickin' out of my models - I just fail to see how that one worksBig Smile [:D]
Posted by Anonymous on Wednesday, August 13, 2003 11:45 AM
wibhi2 - I think someone once told me that the nose weight in my aircraft models was meant to go on the INside. Oh, well I live, I learn.
Posted by Anonymous on Wednesday, August 13, 2003 12:41 PM
next to actually sitting down and reading the kit's instructions, dry fitting would be most helpful... u can always learn these little tips the hard way, like me !
now i try to remember 3 main things:
1) read the instructions all the way thru before starting
2) dry fit all assemblies first
3) take ur time and don't rush the build; if ur in a hurry, the finished model won't look as good as it might otherwise
i know, very basic... but sometimes i forget, and then i get to regret not doing it. luckily, no malpractice on this kind of plastic surgery Wink [;)]
frostySmile [:)]
Posted by Jim Barton on Friday, August 15, 2003 4:19 PM
I'm forever dry-fitting. Dry-fitting is especially important when scratchbuilding your own parts or adding detail. Making your own parts sometimes involves close tolerances or odd shapes, so dry fit, dry fit, dry fit. Also, read the instructions thoroughly and even write notes to yourself on the instruction sheet, particularly if you scratchbuild or buy extra detail parts not in the kit. Otherwise, you just might forget that photoetched ejection seat pull handle until after you get the canopy painted and glued into place!
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
