PCSing
PCSing
Posted by Anonymous on Sunday, May 21, 2006 3:37 AM
  There are a lot of military folks on here. How do you prepare your models for shipment? Im PSCIng next month and have bubble wrapped all of my submarines and other models. I then put them into study boxes with lots of popcorn and padding to fill out the box and prevent the models from banging around.
Does anyone have any other useful tips?
Posted by Rob Gronovius on Sunday, May 21, 2006 7:31 AM
If possible, hand transport any valuable built up models. I've given up on safely transporting any 1/35 scale armor with my household goods.
    February 2004
Posted by LemonJello on Sunday, May 21, 2006 8:05 AM
I have to agree with the above.  If the model is important to you or valuable, it's best to transport it yourself.
Another suggestion is to put the individual models in plastic bags, so that if small items break off they'll be easier to locate and you won't be scratching your head trying to figure out which piece goes with what model.
I've had so-so luck with my PCS's.  Nothing I couldn't fix pretty easily, but plenty of little repairs once I got them out of the plastic containers and styrofoam peanuts.
Good Luck.
A day in the Corps is like a day on the farm; every meal is a banquet, every paycheck a fortune, every formation a parade... The Marine Corps is a department of the Navy? Yeah...The Men's Department.
    January 2003
  • From: Upper left side of the lower Penninsula of Mich
Posted by dkmacin on Sunday, May 21, 2006 9:32 AM
Believe it or don't, but FSM had an article on this subject back in the early 90's
(I should get paid for this huh Matt?)
Anyway,  it involved plenty of TP, one roll per model and you just wrap them,and  wrap them, mummy like.
Mine was a PCS from Alaska to Chicago and only one model had a broken piece.
I had F1 cars, Indy cars, tanks, airplanes and cars. I lost the machine gun barrel on the .50 of my M2, which I should have removed in the first palce!
However, for the most part, moving companies will not cover models in a move. . .(but remember to call them adult collectables and they mightSmile [:)]) if you let them pack. But they will survive better if you pack.
Take this with the usual grain of salt since I haven't PCS'd in 12 years.
Good Luck and thanks for your service to our country.
Don
I know it's only rock and roll, but I like it.
    December 2005
Posted by jeff on Sunday, May 21, 2006 11:54 AM
I don't have anything to add for built models, but for unbuilt, you may want to consider taking out the decal sheets and hand-carrying or mailing them.  With summer coming on, its hard telling how long you're goods may sit on the dock in a sealed transport container baking in the sun.  Let us know how it goes and any lessons learned.  I expect my next PCS in about two years.
"Congratulations, gentlemen! You're everything we've come to expect from years of government training." Zed (Men in Black) [IMG]
Posted by ckfredrickson on Sunday, May 21, 2006 12:19 PM
As usual, Swanny has some helpful advice on this topic too:
http://www.swannysmodels.com/Packaging.html
    April 2005
Posted by wing_nut on Monday, May 22, 2006 7:05 AM
I once shipped a fragile piece of pottery across country without incident.  The trick is for the piece to held firm so there won’t be any movement and then, a protective layer around it.  It was packed in foam peanuts in a box which was in turn put in a second larger box surround with a 2 inch layer of peanuts.  A built model packed in peanuts will shift a bit and the fiddly bits can break off.
The link below is for a variation of a wooden carrying case I saw on line.  It holds the model very secure, no movement at all, but for shipping you may want to use the wing Velcro too.  If this was used in the bottom of a box that could be put inside a second with peanuts, in theory, it will work. I imagine this can be modified to be used with any kind of built model.
Hmmm…  I need to do some work on my roof soon... may just be able to test that theoryBig Smile [:D]
http://wingnutmodels.com/Transport%20Box.html
Marc
