Kit quality!
    March 2006
Kit quality!
Posted by Yann Solo on Tuesday, May 23, 2006 10:27 AM
I'm fairly new at modeling and I haven't try all manufacturers but I can see some differences in the quality of each kit.  Most modelers can handle these imperfections easily but sometimes it can be frustrating.  Here is what I like about kits and what I don't:
I can deal with flashes, pinholes or misalignement of molds but I don't like the lack of details of certain kit.  Example: The complete interior of a trailer molded in only one piece (ammo, cans and boxes) !!!!  I hate huge surface molded details.  Separate pieces please!
What I don't like also is poor engineering; I mean when parts are made in a way that it is very difficult to assemble. (No locating holes for example) I experienced that on my last Italeri kit; the shields of the FLAK gun are held by two pins that has to be glued at a certain angle but there is no guide or instructions about these angles so you have to assemble the shield in place with its two pins all together on the frame, practicly unfeasible.  I finally managed to have it done but its all bent and wrongfully located.
But even then, when I look at the final result, I'm proud of what I've done.  When I started to build the Italeri Sd. Kfz. 10/4 with FLAK, I was sure it wouldn't be my favorite cause when I opened the box, I noticed the poorly molded parts and thought that the result would be ugly.  But when I look at it now, it is my favorite ... for now ...  You can see it here http://www.finescale.com/FSM/CS/forums/624710/ShowPost.aspx
So, don't let the bad reputation of a manufacturer ruin your chance of having your favorite model on your shelf.
No matter where you go ....... there you are.
    April 2005
Posted by wing_nut on Tuesday, May 23, 2006 7:23 PM
I agree with you Yann, “…don't let the bad reputation of a manufacturer ruin your chance of having your favorite model on your shelf.”  But at the same time you still need to be aware of some stinkers out there.  That’s one of the great things about this forum… there are lots of knowledgeable people that can steer you away form some of the really bad stuff.   Like the He 115 I started and put off the side…for now.  I was just not up to the challenge.  This came right after a long time consuming build.
When I was into wood working I looked at it like model building but I had to make the parts first then put it all together, making adjustments along the way.  I still kind of look at it that way.  But the model manufacturer has at least given me the basic shape of the part.  They just need to be refined to get them to fit together just right.  Its how much refining that has to be done is what is determined by the kit maker. Tamiya and Hasegawa needless to say need less refining than some of the others.  The ICM Yak 7DI took some work but I sure am glad I have that on my shelf.
Great job on the Sd. Kfz 10/4 btw.
Marc
    July 2003
Posted by zokissima on Wednesday, May 24, 2006 9:08 AM
Meh, I don't even bother with reputations and reviews. I'll read them to get an idea for the kit, and more often, just because I'm curious of the kit. But reviews and reputations will have little sway in terms of whether or not I'll actually buy something I want. You can always detail it yourself. For me, half the fun is the construction, so cleanup and things like that don't bother me too much.
    March 2006
Posted by Yann Solo on Wednesday, May 24, 2006 9:19 AM
Yeap! But I think it's important to know in advance the kind of work a kit will require.  No surprise!  If I know it's gonna be tough, it won't bother me much but if I have expectations about a kit, I will be mad.  I expect Tamiya kits to fit perfectly.  And I will plan some time to clean up Italeri parts.
    August 2005
Posted by eizzle on Wednesday, May 24, 2006 6:06 PM
I have noticed that most Hasegawa and Tamiya kits are usually a pretty good fit. I did have one Academy kit that was awful, I mean so bad I assulted it with bottle rockets Big Smile [:D] but I am also building the 1/32 F-18 C and it impressed me so much I bought the D as well! I have only built one Italeri kit, and the detail just wasn't there, much like the one MiniCraft kit I built, it was just sad, the instructions had paint call outs, but no list was on the instruction sheet! I have a 1/48 BlackHawk that I will probably never build, or throw together and give to my nephew from them. The instructions on it are pretty bare as well. Sometimes reputation should be considered, which is why I like the reviews, but other times, it might just be a bad kit, or a bad part that is the cause of the problems.
Colin
 Homer Simpson for president!!!
Posted by Rob Gronovius on Thursday, May 25, 2006 7:45 AM
Remember, most of the big names in modeling, Tamiya, Italeri, Revell, Monogram, Hasegawa have been around since the 1950s and 1960s. Many of them have merged (like Revell-Monogram) or taken over defunct manufacturer's molds (Monogram has Aurora; Revell has Renwal; Italeri has Peerless Max and Esci) and all of them have reissued kits from the good old days in current or vintage packaging.
While some kits are aimed at collectors or older builders who are feeling nostalgic, many newer modelers do not know the history of the kits and buy them expecting a new tool kit from the 21st century. Those folks may be disappointed with what they find.
The Flak kit you had is an old Esci kit from the 70s or early 80s. Not a bad kit in its day but not up to the current Dragon or Tristar releases.
    October 2004
Posted by overkillphil on Thursday, May 25, 2006 11:20 AM
Sometimes you're just screwed by limited selection.  I'd really like to build a an F7U Cutlass, but in my preferred scale of 1/48, the only kit avalable is the Hobbycraft which is a real dog of a kit according to most reviews.
Personally, I get irritated when a manufacturer makes a really egregious mistake like putting panel lines on the upper wing surface of the X-32.  The X-32's wing was cast in one piece yet Italeri or whoever went to the trouble of putting engraved panel lines on it,  Then there are the little details like cockpits that look nothing like the original.  I once built a kit where the kit showed a sidestick control while the plane actually had a conventional stick.  Pretty elementary pieces of info.
my favorite headache/current project: 1/48 Panda F-35 "I love the fact that dumb people don't know who they are. I hope I'm not one of them" -Scott Adams
    July 2013
Posted by DURR on Saturday, June 3, 2006 5:34 PM
a different title (here)  but many of the same comments  and the same issues as the other currently very popular post about "shake and bake " models
Posted by tigerman on Saturday, June 3, 2006 11:24 PM
I agree. It's nice to have reviews to help prepare for problems or deficiancies. Helps when ordering upgrades.
 Eric
