Questions, questions, questions... Pros and newbies please POST!
    May 2006
Posted by CaptainHawk1 on Saturday, July 15, 2006 1:10 PM
Many of you probably do not know me but I am Shawn and I am new to the forum.  I have been modeling Star Trek ships for 9 years nad basically never knew wht the hell I was doing.  Everythng I have learned, I learned through trial and error and as I recently have gotten serious about modeling again I have several questions for those of you in the forum.
What I don't think many of you regulars realize is that you use terms and refer to things as standard operating procedures that many of us are completely out of the loop on .  So, I'm starting this thread to discuss all of the things that come up here that I need more info on and I'm sure others have questions on.
So if you have the answers to these and other questions, feel free to inform the ignorant among us.
And if you are like me and are equally clueless, throw your own questions up here.
1.) What is "silvering?"
2.) Why should I only apply decals (especially aftermarket decals) to glossy surfaces?  I've used decal setting solution before on matte surfaces without a problem.
3.) Can you mix brands of paints?  What I mean by this is that, for example, I have purchased 2 cans of Tamiya spray, one flat white, one pearl white.  Now I couldn't find 2 small jars for touch up of the same colors in the same brand.  However, I have Model Masters flat white coming out of my back side, so if I do touch up with the Model Masters on a model that I painted overall with the Tamiya spray, will they match?  The question really is, are different brands with the same color name universally the exact same color?
4.) What's up with Future? What is it? Why do you need it?  How do you use it?
5.) Are Prismcolor pencils used for dry detailing and weathering and where can you get them?
6.) I have had a tendency to lose parts in the past that there were multiples of (so I'm short on one particular part).  What is the easiest and cheapest way to make a mold of the part I have and duplicate it?
7.) What is a "wash?"
Please help me with these questions and more...
"Never mind...it's just easier to call you stupid." -Brian Griffin
    August 2003
Posted by bilbirk on Saturday, July 15, 2006 1:31 PM
Welcome to the Forums .Sign - Welcome [#welcome]Try out this site swanneysmodels.com I go there all the time.
    August 2004
Posted by Tankmaster7 on Saturday, July 15, 2006 1:33 PM
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    May 2006
Posted by CaptainHawk1 on Saturday, July 15, 2006 1:35 PM
Just tried it, address no workie.
    May 2003
Posted by DrewH on Saturday, July 15, 2006 1:48 PM
First off Shawn Welcome to our silly place, uh, forum. Sign - Welcome [#welcome] Please post often and share your wisdom.
Don't feel clueless or anything else. I had similar questions before and the great bunch here helped me through it. This is why it's here.
OK, silvering is term where the decal is not set to the model correctly. Air is trapped under it and the clear part "looks" like it has a silver color to it. A decal 'prefers' a gloss surface do stick to. Think of gloss finish as a fresh sheet of ice. Very smooth. No high spots. Think of flat finish as the road. Looks smooth from a distance, but is rough. Has several high spots and low spots. The decal will stick to flat finishes, but only to the high spots. The air gets trapped in the low spots, causing silvering. On a glossy surface there are no, or minimal low spots for air to get trapped in. The decal is flat down on the surface so air doesn't get under it as easily. Can still happen, but it minimizes the risk of silvering.
Paints. Oh boy. Colors from different companies will not be the same shades. I know, even with the FS number the same, the do differ. It is good practice to not mix different types of paint. No two acrylics use the same liquid to carry the pigment color, often called vehicle or carrier. Enamel are a bit more compatible, but you never know. Once paint has cured, two days for flat paint, a week for gloss, you can paint over top with what ever brand you like if you spray with light coats and build up the color slowly. The paint may affect the paint underneath otherwise.
Future is a cheap, durable clear gloss we use. Look here for uses an Future. There is tons of useful info on this site. I have it bookmarked for emergencies.
Prismacolor pencils are available in most art supply stores and large craft stores.
Loosing parts is a problem that gets all of us. Evergreen plastic, found in hobby shops, is our friend. Try to only cut one part, glue it on, then get the next one. It helps me. Casting parts in resin is not that cheap. Mold rubber can be difficult to use, and small parts are very difficult to make without air bubbles in them. The equipment needed is not cheap and not worth it to most modelers.
Hope it helps;
Drew
Take this plastic and model it!
    May 2003
Posted by DrewH on Saturday, July 15, 2006 1:51 PM
It worki, I just used it. Try the one in my thread and just click on it. Click on the word "here" that is highlited in red
Your air support has arrived!
Drew
