Need help as soon as possible !
    October 2003
Posted by denniscermak on Wednesday, July 26, 2006 6:56 PM
Have just opened an account at photobucket. Followed instructions and got as far as uploading the image ( which came thru alright ) and highlighted the the img part. Thats where I am stuck. Held down the CNTRL key and the  " C " key as instructed and thats where it ends. Nothing happens. What do I do next to get the photo over to the FSM aircraft forum site. Please help. Please contact me at my website at dsc070744@wowway.com with as much detailed instructions as possible. Really will appreciate it. Dennis, Fraser, Michigan
jwb
    February 2006
Posted by jwb on Wednesday, July 26, 2006 7:18 PM
See if this helps.
1. Have your photo displayed in the photobucket page. Select the image tags that begin with [IMG]- making sure to get everything.
2. When it is fully selected, hit Ctrl+C. This is the shortcut to Copy the selection.
3. Go to the window where you have an FSM pag eopen, with the reply window up.
4. Place the cursor in the editing window (the place where you type in a reply).
5. Hit Ctrl+V on your keyboard. This is the command to paste the selection.
That should do it.
You can also use menu commands, typically under "Edit" in your browser application.
Hope this helps!
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
Posted by ajlafleche on Thursday, July 27, 2006 10:37 AM
Alternatively, right click the image, choose"Properties", then triple click the address and choose "Copy". (starts with http and ends with jpg)
Go to the post where you want the picture, right click and choose "Paste". Add the html tags of img in brackets at the beginning og the address and /img in brackets at the end. that SHOULD insert any web image into your post. Doesn't always work here for some reason, however.
    May 2005
Posted by Bgrigg on Thursday, July 27, 2006 10:55 AM
Right click context menu does not work on these forums. You must use the Ctrl-C & -V commands!
I built a tutorial to assist you in your other post.
http://www.finescale.com/FSM/CS/forums/648005/ShowPost.aspx
If you have any more trouble contact me via the PM button at the bottom of this post...
Bill
So long folks!
