CA V.S. Tenax
    August 2006
CA V.S. Tenax
Posted by CRJ700 on Friday, August 4, 2006 2:30 PM
Hello,
I ran out of my favorite CA glue. I have a bottle of Tenax that i have never used. Is it (Tenax) the same as regular glue or like CA?? Does it have any gap filling qualities?? Any body use Tenax?? What is it like??
Posted by ajlafleche on Friday, August 4, 2006 2:34 PM
Teax is a solvent, similar to Testor's bottle cement. It has no inherant filling properties, but if you press the partially soften seams together, you may force a bead of molten plastic up which can subsequently be sanded. It cannot be used for PE or resin, only for regular plastic to plastic welds. It is very volatile, leaving the bottle open overnight will allow much evaporation. I used a technical pen/drafting pen to apply it. (I'm told they're now pretty much antiques--like me!) They are similar to the pen at the bottom of this set.
It's best to place the parts together and run let capillary action pull the Tenax along. That or apply it to the mating surfaces of the two parts and press them together. Curing time is somewhat longer than CA, thus it's very good for indy track links.
    August 2006
Posted by CRJ700 on Friday, August 4, 2006 2:45 PM
Thanks!!
    January 2003
Posted by Triarius on Friday, August 4, 2006 2:52 PM
Ajalafleche has pretty much covered it. You can also use a tool called a "Touch 'n' Flow" applicator or a fine pointed brush (I did that for over 30 years). If you use a brush, just touch or run the very tip along the seam.
Tenax is essentially dichloromethane (methylene chloride). Avoid getting it on your skin or breathing the vapors.
