revel 1/72 sr-71 drone?
    June 2005
Posted by Sasarchiver on Wednesday, December 13, 2006 11:15 AM
hi guys, i got a sr-71 the other day. On opening the box and flicking through instructions, it has a little model drone with it. What is this drone for? I didnt know a sr-71 had a drone attached to the back of it...
sasarchiver
Posted by ajlafleche on Wednesday, December 13, 2006 12:09 PM
Here's your answer.
    June 2005
Posted by Sasarchiver on Wednesday, December 13, 2006 12:58 PM
thnkx ajlafleche,
didnt know that lol So the drone (d21) was put in storage in 1971, mmm, interesting.
thanks again
Posted by ajlafleche on Wednesday, December 13, 2006 1:14 PM
This one is on display at the US Air Force Museum in Dayton Ohio.
    June 2006
Posted by SoD Stitch on Wednesday, December 13, 2006 1:43 PM
The D-21 was a hypersonic reconnaisance drone with a Marquardt ramjet engine. It was designed to overfly "high risk" areas where it was too risky (and illegal) to use the SR-71 (like mainland China). Upon completion of it's pre-programmed flight path, it was supposed to fly out to the ocean and eject it's reconnaisance capsule containing photos, telemetry data, etc. and the capsule retreived by an MC-130 equipped with the Fulton recovery system. After that, the D-21 would dive into the ocean, destroying itself. Several successful launches were made from the M-21 (the SR-71 was called an "M-21" when it carried the drone) before one launch went awry and destroyed both aircraft, killing the RSO in the process. After that, Clarence "Kelly" Johnson prohibited any more D-21 launchings from the SR-71, and it was thereafter launched from a B-52D. There used to be quite a few D-21's sitting out at Monthan-Davis AFB, but most of them have probably been "disposed of" by now.
1/48th Monogram A-37 Dragonfly: 95% (so close!); 1/35th Academy UH-60L: 90%; 1/35th Dragon "Ersatz" M10: 75%; 1/35th DML E-100 Super Heavy Tank: 100%; 1/48 YF-12A, 95%; 1/48 U-2R: 90%; 1/48 B-58 Hustler: 50%; 1/32 F-117, 50%; 1/48 Rafale M: 50%; 1/48 F-105D: 75%; 1/48 SOS A-1H Skyraider: 50%; 1/48th Hobby Boss Su-27: 50%; 1/16th Revell Lamborghini Countach: 75%; 1/12th Otaki Lamborghini Countach: 25%; Tamiya 1/35th M3 Bradley Cavalry Fighting Vehicle: 25%
Posted by grandadjohn on Wednesday, December 13, 2006 8:43 PM
If I remember right, the drone was never used on the SR-71, but on it's predasor, the A-125
    June 2006
Posted by SoD Stitch on Thursday, December 14, 2006 3:39 PM
Technically, you are correct; it was an A-12 with a "Launch Technician" cockpit in place of the "Q" bay, right behind the pilot. If you look at the nose of the M-21 in the first picture, it's slightly "pointier" than an SR's nose; this is usually the quickest way to tell if you're looking at an A-12 or a -71.
