How do you display and clean?
    February 2007
Posted by mitsdude on Sunday, April 1, 2007 12:00 AM
How do you display and clean your models?
Shelves, bookcases, cabinets, etc? Hanging from something? Individual plexiglass cases?
In my part of the country I will have a collection of dust on my models within a week. Even dusting regularly there is a build up of dust. Feather dusters and compressed air can't get it all and sometimes actually break something. Ships rigging seems to be the biggest collector.
I've thought about enclosing my models inside a bookcase by attaching a sheet of plexiglass and weather striping across the front sealing the models inside an air tight case. (assuming the back is already sealed).
The only way I can think of to do this is to screw the plexiglass onto the front of the bookcase with weather striping in between to create a tight seal. It would of course have to have a finished look to it. Lighting could also be added. This would also help keep little (and big!) hands off the models. The downside would be when (and definitely not IF) you needed to get inside to may changes to your display.
I'm aware of curio cabinents and glass display cases but the sizes I would need are way outta my budget.
Any ideas?
    January 2007
Posted by IYAAYAS on Sunday, April 1, 2007 5:16 AM
I just use my A/B (without paint of course) and spray air at about 20psi.  But you can buy the case used to display footballs, they're about 12" - 18" long and about 6" wide.  The cheaper ones are about $10 a piece, and depending on the size of your kit, can hold 2 builds.
BTW your idea is a pretty good one, and would work, t won't keep ALL the dust out, but would certanily help!
    March 2007
Posted by MrKipling on Sunday, April 1, 2007 11:22 AM
For one of his tall ships, a friend of mine picked up a used aquarium at a yard sale and then made a base to place the tank upside down on.
Thin plexiglass sheet and a little CA can allow you to fabricate cases to any size you need for individual models.
Years ago, I got a pair of showcases from a gift shop. The display was 2' x2' x6' with a storage area in the base. Keep my unbuilts below and rotate the display in the top. You could check when a retailer closes up and try to get a store fixture like that - but move quick, a lot of that kind of merchandise gets snapped up by other retailers.
    February 2006
Posted by ruddratt on Sunday, April 1, 2007 2:27 PM
If you plan on using plexi in front of a bookcase, make allowances for expansion and contraction due to temperature changes. While it may not be apparent on smaller panels, warping and/or buckling can become quite obvious on larger pieces that are firmly anchored in only a few places.
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    July 2013
Posted by DURR on Thursday, April 5, 2007 12:32 PM
displays Can be more expensive than the models in it
Posted by jhande on Saturday, April 14, 2007 4:50 PM
Any ideas?
Before I displayed mine in a cabinet, I used to give my models either a shower or bath using the kitchen sink sprayer. Then using a hair dryer to blow dry them. Now they remain relatively dust free. All I need to do is an occassional air blowing from the exhaust of the vacuum or my AB. But it's easier having highly waxed car models I would imagine than flat painted ships or armor.
Why not make a wooden frame and insert a piece of glass instead of plexi in front of your bookcase? Plexi will bow/warp plus haze after awhile. You can get trim molding from the lumber yard, route out a groove for the glass to sit in, screw on some hinges, stain or paint and your good to go. Or find someone that can make the door/frame for you? I've been playing with wood for a long time and have made lots of neat stuff. I saved some serious bucks doing it myself and it's fun too.
-- Jim --
"Put the pedal down & shake the ground!"
    July 2013
Posted by DURR on Saturday, April 14, 2007 7:36 PM
of course if you build your own form of display  that too can be like building a model
Posted by Anonymous on Sunday, April 15, 2007 10:53 AM
I have the same problem. we are having our air ducts cleaned this week,maybe that will help
    November 2006
Posted by buildit on Tuesday, April 17, 2007 7:29 PM
Here's how I've started displaying some of my favorites...
I started making these individual shelves so I could put the models virtually anywhere I wanted, and set them at an angle to allow a better overall view of them.  My wife says I should start making and selling them.  Confused [%-)]
As for cleaning, right now it's pretty much a "swiffer" thing.
Posted by Anonymous on Wednesday, April 18, 2007 9:03 AM
I went to a local art store and bought a big, soft bristled painters brush, and use that to dust.  It works well, and since I am careful, it doesn't harm pitot tubes, antennae, etc.
    October 2004
Posted by jschlechty on Monday, April 23, 2007 10:29 AM
I walked to the nearest Wal-Mart and bought a large make-up brush.  It's also very soft and does an excellent job of removing the dust without taking off small parts , wires, etc.  And, because it was at Wal-Mart, it was cheap!
