Best adhesive for assembling acrylic display cover?
    January 2006
Posted by dirkpitt77 on Monday, April 23, 2007 2:59 PM
     Hey guys,
      I was going to have some 1/4" acrylic cut to size to build a rectangular diorama cover, and I was going to assemble it myself.  I think I'd heard that Tenax can be used to glue acrylic together-is this correct?  If not, what is the best adhesive to use for this?
   Thanks
             Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    February 2006
Posted by ruddratt on Monday, April 23, 2007 3:35 PM
Don't use Tenax. The proper stuff to use is methylene chloride, also known as dichloromethane, which is fed via syringe to adjacent edges of the plexiglass, and actually 'melts' it together. See if you can get your hands on some right-angle clamps. These will hold the two parts together at a right angle to each other and make your job a lot easier. There are other products available for bonding acrylic, but this stuff is by far the best, and it works FAST. The joint will be virtually unbreakable if done properly.
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    January 2003
Posted by Triarius on Monday, April 23, 2007 4:19 PM
Acording to the last MSDS I examined, Tenax is methylene chloride, aka dichloromethane.
However, you are going to be using a lot of it, and Tenax is rather expensive. Look up plastic supply houses in the phone book. Most of them will be happy to sell you a pint, quart, or gallon. You will then have a supply of solvent cement that will last half a lifetime, if you don't leave the cap off.
One commercial name for the stuff is Caseway SC-125. They also sell several inhibited versions that evaporate more slowly and give you more working time. Here's the link to their website
    May 2003
Posted by qmiester on Monday, April 23, 2007 6:32 PM
Ross is correct, check out your local plastic supply houses.  I started using methylene chloride when IPS Weld-On #3 became unavailable.  The brand I use is listed locally as Pleximent - I purchased a gallon about 4 months ago and it cost me $23 - which is a heck of a lot cheaper than the $3.99 for the last 2 ounce bottle I purchased   Note: The plastic supply house I get it at informed me they would no longer stock Pleximent but would special order it for me in gallons only
Quincy
    January 2003
Posted by Triarius on Monday, April 23, 2007 6:44 PM
I forgot to mention: make sure you get acrylic and not polycarbonate.
    January 2006
Posted by dirkpitt77 on Tuesday, April 24, 2007 11:49 AM
     Thanks for the  help guys.  Found a source for some stuff called IPS #3 or something like that over at the plastics shop.  I am going to call on my lunch and price it out.
            Chris
    February 2006
Posted by ruddratt on Tuesday, April 24, 2007 12:43 PM
How are you having it cut? The reason I ask is because I have about 25+ yrs experience machining and assembling materials like that. If it is being cut with a saw, no matter how fine the blade or straight the cut, the edges will be somewhat rough and a fine viscosity adhesive will not work as well as one that is thicker. I was able to machine plexiglass on a Bridgeport mill using a 3-fluted bit with kerosine as a lubricant down to tolerances of +/- 0.0005", which would give me a perfectly smooth and flat edge to work with...ideal for fine viscosity adhesives. Without a flat, uniform edge, half of your liquid will run out the opposite side, and it is almost impossible to clean up the residue. You will most likely need a heavy viscosity adhesive.
    January 2006
Posted by dirkpitt77 on Tuesday, April 24, 2007 3:40 PM
    Well, I go to a local glass shop to get my acrylic, and so far the stuff I've gotten has had a real nice clean edge to it, so I assume they use something besides a saw.  I will double check with them when I order it.   edit:  just reread your post- I will definitely check with them.
       Let me pick your brain on another thing.  The IPS came in various #'s, like #3, #4, #5, #40, #45, etc.  Do these numbers basically refer to the viscosity of the adhesive?
    May 2005
Posted by Bgrigg on Tuesday, April 24, 2007 4:21 PM
The local glass shop likely scores the surface and breaks the piece, just like they do with glass. I've done it myself many times. Use a sharp utility knife, and make sure your cuts are straight, then put something (broom stick, straight edge) under the piece you want to cut and snap the other side down quickly. It should break very cleanly. Much cleaner than you can get with a saw. You can use a propane torch to do minor clean ups, it's called flame polishing in the trade.
So long folks!
    May 2003
Posted by qmiester on Wednesday, April 25, 2007 5:54 AM
Locally the only IPS product I've seen was #3 and that was in the LHS when it was available.  My guess is that the numbers indicate either the "hotness"  or the viscosity (or a combination of both) of the liquid in the bottle.  In other words, you might find that #3 works very well on styrene and fairly well on harder plastics while say #5 works very well on harder plastics but is too "hot" to use on styrene.  My suggestion is to talk to the folks in the plastic supply store and see what they recommend to use.
Quincy
    January 2006
Posted by dirkpitt77 on Wednesday, April 25, 2007 1:37 PM
    Well, turns out I can have them build it out of 1/8" acrylic for about $65 or so.  Should be stout enough for my purpose.  I might just have them do it for me.
    Chris
