Easy, quick, and fun models?
    August 2007
Posted by ben1227 on Tuesday, August 7, 2007 3:38 PM
I recently bought my first airbrush i need about 3 Quick, easy, and fun kits to build to practice airbrushing on...any ideas?
.:On the Bench:. Tamiya 1/72 M6A1-K
    February 2006
Posted by gtother on Tuesday, August 7, 2007 4:21 PM
I'd recommend Academy's 1/72 line.  Pretty cheap, good fit (those two combined make it fun).  I recently built the Bf-109E-3/4.  It was under ten dollars u.s. and needed no filler, but i dont know if you want to begin with splinter camo.
    August 2006
Posted by HawkeyeHobbies on Tuesday, August 7, 2007 7:14 PM
21st Century Toys 1:32 kits are available for under $10 at Wal-Marts across the country. You can knock one together in an hour easily. Then on to the fun...painting!
Gerald "Hawkeye" Voigt
    August 2007
Posted by ben1227 on Tuesday, August 7, 2007 8:47 PM
Alright thanks guys...i noticed those at my walmart so i'll go pick some up.
    July 2013
Posted by DURR on Wednesday, August 8, 2007 7:53 AM
man  i wish i had some good walmarts up my way   i been to 8 looking for those 21st century stuff none of them carry them
    August 2007
Posted by ben1227 on Wednesday, August 8, 2007 8:57 AM
I'd seen the 21st century kits before at wally word before, and they have some kits of cool subjects, i almost got the M7 priest, but as i looked closer all the kits seemed pretty undetailed and basic. But now i need something simple and basic to practice with my new badger :D  so i'll go grab the M7.
    August 2006
Posted by HawkeyeHobbies on Wednesday, August 8, 2007 3:32 PM
Here is a Bf109 that I slammed together in just a couple of hours from start to finish using only cement, knive, putty and sanding stick. The painting took longer than the build itself. It was all for fun to see what the kits were about. For under $10 it was a hoot.
I can search the local WM here for kits if anybody is interested. I know there were a couple of 109s left where I got mine. We have four WM Superstores within 18 miles of each other.
Posted by BlackWolf3945 on Wednesday, August 8, 2007 3:49 PM
If you like little things with wings, most of the 72nd kits from Hobby Boss are actually quite nice. They're fairly accurate, and all are simple to assemble; there aren't a helluvalotta parts to any of them, and the fuselage and wings are each one piece... my MiG-3 was totally assembled and cleaned up in about 45 minutes. Painting and weathering will of course take the normal amount of time, but that's the fun part of building, for me anyway.
They're also inexpensive... I think the retail is $7-8 each.
Fade to Black...
    August 2007
Posted by ben1227 on Wednesday, August 8, 2007 4:14 PM
You make the 109 look soooo easy hawkeye Tongue [:P]    -i could assemble it almost as well as you did in that picture but i can't make that paint job...After all these kits are for me to practice airbrushing on :-]
    August 2006
Posted by HawkeyeHobbies on Friday, August 10, 2007 9:00 AM
The paint scheme is a simple three color one. Upper base of a tan, lower light blue and the green is freehanded with the airbrush. Models like this make great test mules to practice on. If you don't like the way it turns out, give it an overall coat of a light gray and start again and again. Practice by doing solid colors first, making sure you are getting a even coverage. You can practice this by doing a light base coat then apply a darker one. Watch the pattern your airbrush lays down. You can adjust the pattern by the distance you hold the airbrush from the model while spraying. **Remember light coats are better than solid thick ones.**
What type of airbrush are you planning on using, single or double action?
Trace an outline of your model on a large piece of paper. Use some cheap acrylic paints to practice your strokes. Once you're comfortable with doing base coats, then try free handing details such as blotches, lines, patterns. You'll do well, just takes a little time and practice. Building models is the same, clunky at first, refined later.
Cheers!
    August 2007
Posted by ben1227 on Friday, August 10, 2007 11:01 AM
OK now, don't freak out...Bgrigg talked me into it! It will have a steeper learning curve but I'll never have to upgrade my airbrush...itsa Badger 100LG Cool [8D] With a Paasche D500...this is off topic but what do you think of that? Should i have gone with a Badger 180-10? And, i don't think anyone airbrushes without a regulator...but i didn't order one so idk.
    August 2006
Posted by HawkeyeHobbies on Friday, August 10, 2007 11:14 AM
Regulators are a required item in my book. Compressors pulse pressure too much even with used in conjunction with a holding tank. Regulator and moisture trap...are REQUIRED accessories!
I have several airbrushes. I have Paasche, Iwata and Badger as well as an old Binks. They all apply paint well, though I am using the Iwata's more because of their versitility and simplicity. Any airbrush is only as good as the operator. Granted some do better with fine detail by design where other cover larger areas but don't do well with intricate work. I use single action for large overall coverage applications and the doubles for medium coverage to fine detail work. I try to airbrush as much of a project as I can including small parts.
    August 2007
Posted by ben1227 on Friday, August 10, 2007 11:17 AM
Uh-ohh...Someone Give me a link to a regulator lol or tell me one that fill fit a D500 and what i need to adapt it!
    August 2006
Posted by HawkeyeHobbies on Friday, August 10, 2007 3:27 PM
Regulators can be found a most hobby shops or craft stores that stock compressors. You can also look at stores that carrier compressors for light industrial applications...hardware & home improvement centers. You might also venture into your local Sears...err K-Mart....whatever. A regulator can run anywhere from 25-100 dollars depending on brand and capacity. Mine was about forty at my LHS. It has a built in moisture trap, nice easy to read pressure dial and simple pressure adjustment knob.
    August 2007
Posted by ben1227 on Friday, August 10, 2007 4:45 PM
problem is...that stupid D500 has its air valve, w/e its called, you know that thing that you screw the hose on? that thing is placed OVER the the compressor, and i'd have to get some adaptor ti fit a regulator...go to www.paascheairbrush.com and click compressors, D500, and you'll see what i mean.
    August 2006
Posted by HawkeyeHobbies on Saturday, August 11, 2007 7:55 AM
You'll have to visit your local hardware store and take a look at their brass fittings to find the pieces you need to adapt so that your components work together. These parts are relatively cheap compared to what you spent for the compressor and regulator.
