Another dumb question.
    August 2007
Posted by ben1227 on Saturday, September 22, 2007 10:15 PM
I've never figured these things out b/c my hobby shop doesn't carry them and never will, and I've never built one. What exactly is a vaccuum-formed kit? I know they're harder, which is another reason I haven't built one yet. I often see vac-u-form canopies when I'm looking around for A/M canopies on Squadron.
.:On the Bench:. Tamiya 1/72 M6A1-K
    May 2005
Posted by Bgrigg on Saturday, September 22, 2007 11:00 PM
Vacuform kits are the simplest form of making kits. It's no different than the blister packs you find around toys, small electronics, headphones, tools and the like. A vacuum table and a heat source and a form, which can be another kit or a block of wood, is all you need to make a vacuform kit. Heat the styrene, turn on the vacuum and suck the air out which draws the heated stryene over the form. Trim out, sand to fit and you have a kit. The vacuum table can be made at home with a simple box, with the top drilled out and hooked up to a vacuum. Here's an article on it showing how simple it really is.
Vacuform kits are sometimes the only way to build a rare aircraft. Manufacturers aren't interested in investing in an extrusion mold (that can cost upwards of $100,000!) for a kit only a handful of people are interested in.
Vacuform canopies are much thinner than extruded styrene and are much truer to scale thickness. They are also an inexpensive way of updating one version to the newer one. Often times that is all that is the difference in model variations.
They also come in handy when you goof up painting or accidently cut or break canopies. Banged Head [banghead]
So long folks!
    August 2007
Posted by ben1227 on Sunday, September 23, 2007 12:11 PM
Sounds neat, but I probably won't venture there until I get better. How hard is it really to build a V/F kit? I'd imagine you've probably built one...
    May 2005
Posted by Bgrigg on Sunday, September 23, 2007 1:51 PM
Me? No way. Too much trouble! I'm a lazy modeler!! Propeller [8-]
So long folks!
    August 2007
Posted by ben1227 on Sunday, September 23, 2007 4:14 PM
Laugh [(-D] You aren't alone! My two models I'm working on haven't moved in weeks. Still waiting for the airbrush part...Sigh [sigh] I'll go order a V/F kit from Squadron. Cheapest one I can find...just to try. I'll post in aircraft about it soon probably.
    November 2004
Posted by Bronto on Sunday, September 23, 2007 7:18 PM
 Drop me an email I have several old vacu-kits sitting around. I can send you one.  No need for you to buy one.
