How do you get realistic rotor droop ?
    January 2006
Posted by Wirraway on Monday, July 22, 2013 4:47 AM
The title pretty much says it all.  I've only built one Heli before, being a 1/72 Chinook.  Now on the Hasegawa  SH-60B Seahawk.  Getting some authentic looking rotor sag was almost an afterthought, so maybe I left it too late. I did put a bulldog spring paper clip on the end of each rotor while waiting for the glue to dry, but it didnt make much difference.  Whats your method ?
"Growing old is inevitable; growing up is optional"
" A hobby should pass the time - not fill it"  -Norman Bates
GIF animations generator gifup.com
    September 2004
Posted by Borg R3-MC0 on Monday, July 22, 2013 4:54 AM
I do not have much expecience building helicopters but my technique would be warming the rotor blade (warm water or a hair dryer) then bending it in the desired curve.
    February 2013
Posted by Raven Morpheus on Monday, July 22, 2013 8:43 AM
The technique I've seen is to assemble the rotors on the hub, don't attach the mast if you can, then put them upside down on a plate and place weights in the middle.  That then pushes the middle downward and when left for long enough the rotor blades bend to look like the sag you're after.
And example can be seen in Helo 53's HH-3E build on page 2 post #28, here - s362974870.onlinehome.us/.../index.php
    February 2013
Posted by Raven Morpheus on Monday, July 22, 2013 8:50 AM
Just an afterthought, I'm guessing that if you've assembled the main rotor including rotor mast, but haven't attached it to the main body (or it simply lifts out anyway) you could do the reverse of what Helo 53 did -
Put the rotor the right way up but on top of an open jar or cup or mug or something to accommodate the rotor mast and place a plate on top.
Although the blades might snap doing it that way due to the sudden increase in weight, I'd do it very very carefully, but it might work.
Posted by gregbale on Monday, July 22, 2013 10:09 AM
Find a large-size cooking spoon with a curve that matches your desired blade droop. Spoons are ideal for this, since one part of the "bowl" is usually a sharper curve, that tapers off to a more gentle or almost straight contour toward the handle--you can easily choose where your droop goes. A few good sturdy rubber bands, and you're ready to go.
From my recent 1/144 Sea King:
Bring a pot of water to a boil and take it off the heat, dip the spoon with rotors in for a slow 30-count (approx. 30 sec.), then run the spoon under cold water for about half that time, and they're done. It gives you a uniform curve on all the blades, and it's fast.
Greg
George Lewis:
    April 2010
Posted by Theuns on Monday, July 22, 2013 11:13 AM
The way I do it is to CAREFULLY  mold the droop into the blades by forming them between my fingers. I basically put a slight bending moment on the blades abd then pull them out of my fingers to form the curv. Thus does take some time as I only do a little bit at a time not to over stress the plastic.
I also mace a template to make sure they all have the same droop to them.
Remember that blades usually droop or bend more in the first 1/3 and tend to become a little straigther or droop less towards the tip as the weight of the blades become less.
I attatch a pic ov my 1/72 MiL 35's blades to see how straight molded blades can be bent with fingers.
Theuns
    January 2006
Posted by Wirraway on Sunday, July 28, 2013 12:39 AM
Thanks Guys- some good tips there !
Posted by midnightprowler on Sunday, July 28, 2013 12:51 PM
I gently pull the blades over the edge of a table.
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
    November 2013
Posted by Spitfire on Wednesday, July 2, 2014 12:29 PM
I'm currently working on the Revell 1/48 Apache.  I recently had a thought on this topic and was wondering if this would work.  Since it is now summer I thought maybe use the inside of a car as sort of an oven.  I could stick the rotors inside the hot car (out of direct sunlight of course) with the blades weighted to the desired droop, then essentially 'bake' them for a certain time period.  It seems to me it could work.  The only question would be is how long to let them sit inside the hot car.
    January 2014
Posted by Rob S. on Thursday, July 3, 2014 11:53 AM
Great tips, gonna try one of these techniques when I get on to my Hobby Boss Helix..Thanks!!
______________________________________________________________________________
On the Bench: Nothing on the go ATM
