WarHammer25 wrote: |
The MH-6 is not the bird that the 160th SOAR uses. They use the AH-6 Little Bird. |
That's not quite correct: the 160 uses both the MH and the AH. First is, as gmcookvt says, a "troop carrier" while the AH is the attack version.
The "Little Bird" was developed on the "Loach" airframe, but has become something completely different nowadays.
As for the armament the "standard" load out is two M-134 Miniguns and two 9 FFAR pods. The only variation I have seen depicted is a three barreled .50cal machine gun on each side, without rocket pods.
Regarding the kits I don't know them, since i "work" 1/35.
But as far as the Black Hawk goes, I heard you'd be better off getting Italeri's Pave Hawk kit and Cobra Company's update set, since the Italeri's "kilo" doesn't have the miniguns.
There are also two phtot etch sets by Eduard one for the interior and one for the exterior.
You also should get Cobra Co's decal sheet, because the one in the kit has black lettering and it's hard to see black stecils on a black background!!
HTH
